Moving the Engine Back
does anyone know what is the best method to move my engine further back?
has any one even moved their engine further back?
EJ22 into an MY btw.
i need more clearance between teh Rad and the engine.
it looks like it will be easier to move the engine back a little bit than trying to relocate the Rad further forward.
Wagon is no longer....
- Outback bloke
BYB - Yer actually makes sense. Altho when i get the new 5 speed gearbox slotted back in ill have to do some shifter modding and figure out the crossmember. But tailshaft is a good point.
My fans are on the front of rad atm and coz the engine has moved downwards its also moved slightly forwards. So now touching the rad. Mainly the passenger side camcover is hittin on the bottom hose outlet (which comes out then bends down atm)
It doesnt look to easy to move the rad either but ill have another look tonight.
SUBARUTE - are u saying that everything will fit with a 3 inch lift and ej22 behind a dual core rad. Maybe it is actually only the rad outlet and i can get that modded without restricting the outlet size.
It is hard to figure out exact clearance as the motor isnt held up by havin a gearbox on and wants to fall forward lol.
Input is appreciated.
Don't forget moving engine back will also put more angle on your CV's. You'd need custom engine mounts I'd say.
You could move the entire engine crossmember back which would keep your front hubs in the same place in relation to the engine and prevent the CV angle changing...
but this would put the front wheels closer to the firewall so cause more scrubbing. You'd also need to modify the steering extension, probably shorten it.
Seriously tho, its much easier to just mess around with the radiator and fans.
- stamp_licker
Actually I have heard that you can use thin fans - I forget where and which car - I think it was either Merc or BMW.. not sure I recall it was only 1 and half inch thick
Have you got an engine stay rod to stop the motor moving forward and back??
Also... have you thought about dropping the gear box crossmember... this will angle the motor backwards and actually move it away from the radiator a bit.
Just some ideas to think about there.
Dave
Dave
good points there.SuBaRiNo wrote:Have you got an engine stay rod to stop the motor moving forward and back??
Dave
Stay Rod - had one yes. but is now to short for Lift. so will make another up.
and havent got a gearbox in atm but it is a thing to look at when it goes in yes.
the main problem is my bottom rad outlet hitting the passenger side cam cover. which im thinking wont really clear if i was to only drop gearbox down a touch.
but things to think bout yes.
Ohh i get ya... radiator mod time. I wonder how mine differs from yours.
Dave
Dave
- Outback bloke
yer. Had a quick look last night and even tho the engine was tied back it was still leaning forward alot.
Tied it back further and now i can see that i need to get bottom rad outlet modified and it will all fit up.
Altho wont be sure on exactly how much clearance there will be between ps pump pulley nut and the core. Altho now i think it will fit fine.
Thanks
Thanks
ur bottom outlet Dave.SuBaRiNo wrote:Ohh i get ya... radiator mod time. I wonder how mine differs from yours.
Dave
doesnt it have like a 90 degree bend in it to point straight down?
i can actually make do with my top hose from the looks of it without gettin that outlet modified again. (atm its going straight out but was enlarged to EJ size)
I've heard that when you drop a 5 speed into an MY that you need to either use the L series 2 piece tail shaft or shorten(?) the MY one piece shaft. Basically what i'm getting at is that you will need to mod the tail shaft if you want to keep a 1 piece shaft - perfect time to do it if you're going to move the engine back. You're at a good time to do all of this if you decide this is what you want to do...Matatak wrote:when i get the new 5 speed gearbox slotted back in ill have to do some shifter modding and figure out the crossmember. But tailshaft is a good point.
