Forester 2.5 flywheel change?
subanator
Post by subanator » Tue Dec 27, 2005 12:15 am
My brother has bought an '03 Forester 2.5X about 3 months back. He just had it in for a "recall" for a flywheel change. He said it was due to the wrong flywheel fitted on the first 2.5 models, and apparently a lighter one is in there now. Was wondering what is known about this and why?
jzk25
Post by jzk25 » Tue Dec 27, 2005 7:42 am
2.5's around that age had dual mass clutch assemblies with a floating flywheel arrangement. It is a crazy looking setup and is hard to explain what it looks like. Either way they didn't work too well and need to be replaced with a conventional clutch. Surprised they are doing warranty on them though.
subanator
Post by subanator » Wed Dec 28, 2005 11:10 pm
Thanks jzk25, apparently its the first one that dealer has done so far. Better now than later I suppose.
Subyroo
Post by Subyroo » Thu Mar 30, 2006 8:23 pm
I had the Flywheel and Clutch replaced on my 03 XS Forester (75,000kms) on 20-03-2006 as it had a rattle when releasing the clutch in 1st gear.
City Subaru in Newstead (Brissy) did the job as they were recommended to me by The Subaru Shop in Brendale which is a TOP place for having your Subaru Serviced.
subanator does your brother still have a copy of the recall letter that you/he could scan and post in here thanks, not just for my sake but for all other interested parties too.
Peter
subanator
Post by subanator » Fri Mar 31, 2006 12:08 am
I will find out if he's still got it.
Subyroo
Post by Subyroo » Fri Mar 31, 2006 2:10 am
subanator wrote:I will find out if he's still got it.
Thanks matey!
Peter
subanator
Post by subanator » Sun Apr 02, 2006 11:31 pm
Subyroo sorry my brother never got a recall notice. It was probably due to buying the car as the second owner, the original owner would have recieved it?
Apparently he took the car in to be serviced, they mentioned to him that it required mods to clutch and flywheel. My brother said a squealling noise loud like a fanbelt slipping. Was told it was something to do with clutch spring tension. His car was to their "guinea pig" as they hadnt done one before.
jzk25 mentioned in his post above of the other setup. Maybe this was what had been done - converted?
If you want, ring:( 08 ) 9309 2889
NORTH SUBARU 14 Buckingham Drv Wangara 6065 WA
They did the job. PM me if you want my brothers details or contact number.
Subyroo
Post by Subyroo » Mon Apr 03, 2006 1:01 am
Thanks subanator I'll give them a ring and see what happens.
Here's a list of the parts that they replaced on mine:
1 x SU12345AA002 Dual-Mass Flywheel
1 x SU30100AA671 No KUU Noise D/Mass C/PLA
1 x SU44059AA010 Bolt Centre Exhaust Pipe (must have been missing?)
1 x SU28024AC020 Boot Band (leaking inner CV Clamp)
1 x SU806786040 Rear Oil Seal (slight leak on the old one)
Peter
