engines out
FROG
engines out
Post by FROG » Mon Dec 17, 2007 2:22 pm
finally got my engine out it only took 35 minutes from go to whoa (with a little help from my mechanic friend)
ive bought two nice new head gaskets
a set of rings and all the other orings and gaskets etc etc
will post up some pics later on in the week of the breakdown and rebuild if anyone is interested
bluesteel
Post by bluesteel » Mon Dec 17, 2007 2:28 pm
good luck with the rebuild!
Post by AlpineRaven » Mon Dec 17, 2007 4:48 pm
Good Luck and show pics and updates..
Matatak
Post by Matatak » Mon Dec 17, 2007 7:25 pm
complete rebuild aye ??
show pics :D
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
Cam
Post by Cam » Mon Dec 17, 2007 8:06 pm
this the liberty? Na or turbo?
FROG
Post by FROG » Tue Dec 18, 2007 7:06 am
this the na
gunna be a slow job
me and santa will be into it xmas day lol
FROG
Post by FROG » Tue Dec 18, 2007 12:13 pm
WELL WELL WELL
GOT THE ENGINE IN PIECES AT LUNCH TIME TODAY HEADS ARE OFF AND FOUND NOT WHAT I EXPECTED -- THE WATER JACKET HAS NEARLY ROTTED THRU TO THE BORE ON TWO CYLINDERS --- I FORGOT THE CORD FOR THE CAMERA TODAY SO I CANT POST THE PICS I TOOK TIL TOMOZ :-) I TOOK LOTS THO SO WATCH THIS SPACE LOL
Post by El_Freddo » Tue Dec 18, 2007 3:36 pm
FROG wrote: THE WATER JACKET HAS NEARLY ROTTED THRU TO THE BORE ON TWO CYLINDERS
Ouch, that sounds nasty. Have you been using coolant properly?
This will be an interesting write up...
FROG
Post by FROG » Tue Dec 18, 2007 3:40 pm
Yep Fully And Properly Serviced Since I Had It 60 000 Klm Ago Now Has 385 000 On The Clock
Cavitation Seems To Be The Cause Ill Post Pics
Any One Think Its Worth Putting Back Together?????? Or Am I In The Hunt For A Turbo Motor :-) :-)
FROG
Post by FROG » Wed Dec 19, 2007 10:48 am
Found A Second Hand Block So Its A Full Rebuild Now And No Xmas Lunch For The Frog- Pics Coming-
Smokey
Post by Smokey » Wed Dec 19, 2007 3:25 pm
That sux mate! Can you explain to us less mechanically minded how that can happen? Good luck with it :)
FROG
Post by FROG » Wed Dec 19, 2007 4:04 pm
still trying to get my head around it myself but as far as i can gather (and ive been asking alot of questions) the coolant was PROBABLY not used correctly and water was used at some stage or other and water which is heavy with minerals ie bore water conducts electricity now not sure which way round it goes but the water is positive charged and the engine block is negative so from my schoolboy chemistry(which i failed) the engine block gets eaten away by electrolysis....
anyone want to add or show that im totally wrong- im up for more information and answers--- this is what i think anyways---
foot note ---- the hole is deeper than the pic shows i reckon it only has about .020" til it goes thru to the bore
king benny
Post by king benny » Mon Jan 07, 2008 10:13 am
Bummer when things go bad like that!! Just wondering what were your symptoms that prompted the rebuild? I have 315,000 on mine and is chewing some water, is that what you had? best of luck
FROG
water
Post by FROG » Mon Jan 07, 2008 12:35 pm
just had a real strange o' heating problem it was real intermittant and if it did it it would spew all coolant out o'flow bottle i didnt seem to matter what the circumstances where ie off road in the sand or on the bitumen
I had some time off the road :(
so i thought id have a look... i was prepared for everything except for this :mad:
am in the middle of rebuilding an ej 22 now from the block up. will post up when done just too busy atm :rolleyes:
SUBYDAZZ
Post by SUBYDAZZ » Mon Jan 07, 2008 1:19 pm
Please do, am planning this for mine one day, :)
SUBYDAZZ
FROG
Bitz
Post by FROG » Wed Jan 09, 2008 9:47 am
Okay Guys And Girls Ive Got A Second Hand Ej22 Block In Good Condition (for Free :d) Gunna Put All My Bits Into This Block And Bolt My Original Heads On
Any Body Care To Point Out Anything To Watch Out For When Putting It All Together?
Any Reply Is Good
Andy
Smokey
Post by Smokey » Wed Jan 09, 2008 11:55 am
Don't put the heads on upside down.
SUBYDAZZ
Post by SUBYDAZZ » Wed Jan 09, 2008 9:34 pm
Don't have any bits left over! ;)
SUBYDAZZ
FROG
Post by FROG » Thu Jan 10, 2008 11:00 am
SUBYDAZZ wrote:Don't have any bits left over! ;)
hopefully ill have a pile left over as im using two full engines :rolleyes:
or i will have made an ej 44 ????? :D
camera is being bad atm but ill post up gaskets and seals etc that im replacing... pistons and heads are getting cleaned up now im hoping to have them back tomoro so i can get stuck into it all on the weekend ...
cheers
Post by Gannon » Thu Jan 10, 2008 11:30 am
EJ44..... mmmmmm i like the sound of that
