D/R gearbox rattle
littlewhiteute
D/R gearbox rattle
Post by littlewhiteute » Sat Oct 27, 2007 9:23 pm
Hi Guys,
Looking for some info on my D/R 4 speed gearbox.
The car has had a rattle in it since my purchase,
have since worked out it happens at 3000 + rpm in the first three gears AND ONLY in 2WD.
Does not do it any other time, in 4WD Hi or Lo, or 2WD top gear.
Sounds like noisy tappets, the noise is not from the engine, is definately from the gearbox.
Is this a common problem, any help greatly appreciated.
Gary ;)
Post by El_Freddo » Tue Oct 30, 2007 1:00 pm
could be a bearing on the way out?
whats your gearbox oil level looking like?
999 posts...
littlewhiteute
Post by littlewhiteute » Tue Oct 30, 2007 7:04 pm
Bennie,
Yes, I thought it may a bearing, I'd say front cluster bearing. Oil level is ok and quality appears normal, no leaks. It is quite annoying because it actually sounds like it's coming from the motor, rattly tappets. I adjusted the valvetrain to as tight as I dare, the motor sounds good with just a hint a tappet clearance, the timing is at 8 deg, the carb is perfect.
Thanks for your input.
Gary ;)
Post by El_Freddo » Tue Oct 30, 2007 7:26 pm
Could be a good time to drop a 5 speed dual range in it ;)
bpm
Post by bpm » Sat Nov 03, 2007 3:29 pm
i had this exact same problem with my brumby. would you believe it was the tailshaft??!! it was. is it there when you rev it over 3k in neutral? put it on a hoist and get someone to rev it. it sounds like its coming from further up the front but touch the tailshft and its gone. it had a loose uni, so i replaced it and it disappeared for a while, then came back. when i did the 5spd conversion, i had a new shaft made and the guy filled the tube with foam, no noises now. hope this helps.
littlewhiteute
Post by littlewhiteute » Sat Nov 03, 2007 6:54 pm
El_Freddo wrote:Could be a good time to drop a 5 speed dual range in it ;)
It's on the list. ;)
bpm, thanks for the tip about the tailshaft.
Mine does have a slightly worn front uni, will look at it while on holidays soon.
Gary ;)
90brumby
Post by 90brumby » Sat Nov 03, 2007 7:09 pm
yep tail shaft mine did the same new uni fixed it 4 a bit but it came back refilled the uni with grease n it was good again
The New Owner Of hatchie
A 00 outback for doner car
2 door wrx being restored
