Quick engine and gearbox question
I have recently purchased a Subaru 1985 L series Rx conversion
i am getting an engine rebuild and replacing the gear box
Since i am running an Rx engine What gear should i put into the car L series or Rx gear box
I am new this so i dont really know
- steve_rising_sun
Depend on what you want it for. If it has had a FULL RX conversion the you should have the 3.7 LSD and you will need to use a 3.7 gear box.
The other comon set up is 3.9. The RX box and L box have different size stub axles and drive shaft sizes (i think that its 23 or 25... some1 will post 4 u). Neither box is any stronger then any other if thats the kinda think that you were after.
