were there GLs with 4.444 ratio?
well, it seems I've finally found a rear diff for my conversion!!!
the seller told me that it came out of an some old GL model ('89 or something) but I was under the impression that the older models did not use this ratio...
does anyone know if there were any old turbo models made with 4.444 ratio? if yes, will it be OK to connect it to my 4EAT with front 4.444 ratio from a Legacy/Liberty Trubo? just want to make sure before I trash my transmission...
ok... I picket it up today...
it's marked as a '91 Legacy/Liberty and has a 4.444 sticker on it... does that mean it came out of a Turbo Liberty AT?
it's a direct bolt on for my '89 GL Coupe!
I can also get a 4.444 diff out of a '02 Outback but that requires some shaft modding... think I'll just stick with the older model for this time and try it out...
- Outback bloke
- Outback bloke
If the ratio is the same then it is fine. Does it have a sticker on the back saying 4.4 ratio or is it just what the bloke said? I am not saying he is lying, just that he may have been ill-informed. I would take the back cover off and do some counting to make sure. You will have it off any way to convert it to LS.
