Homemade g/box rubber mounts.
stamp_licker
Post by stamp_licker » Mon Sep 03, 2007 6:12 pm
Anyone made their own g/box mounts?What were they made out of? how have they held up?Wanting something longer lasting than the standard rubber mounts.
PICS PAGE 4
Building a hardcore postie:D
Post by El_Freddo » Mon Sep 03, 2007 6:16 pm
Hey postie, nice name change...
Dunno about making entirely new mounts but i've heard of people welding 3 chain links to the mounts so that their movement is restricted. I don't know how harsh this sounds when the mount meets the chain's length, i've only heard of it being done.
My 2c.
vincentvega
Post by vincentvega » Mon Sep 03, 2007 7:19 pm
which mount is breaking postie? the auto gearbox crossmember mount?
stamp_licker
Post by stamp_licker » Mon Sep 03, 2007 7:36 pm
Yep both sides of the g/box mount are bust,the rubbers aren't perished just seperated from the metal.Explains why the sump was touching at Longreach the whole box and motor has shifted,possible the cause of the vibrations i had.So close to becoming a manual.
vincentvega
Post by vincentvega » Mon Sep 03, 2007 8:22 pm
lol
just replace the mount and see how you go. They are $120 new. My GX ones are completely torn, have been for years. Gearbox clunks around every time i start the car.
The VTD mount that came with my rear housing is in good nick though, and its done about 100,000kms in TT cars
I would try replacing with a new bush, and if you tear it again you probably have some other issue causing it (torn engine mounts? misalignment of your crossmember etc)
BaronVonChickenPants
Post by BaronVonChickenPants » Mon Sep 03, 2007 8:25 pm
Maybe the engine needs a stay rod to stop it pulling forward causing the mounts to tear? Just a theory.
Jordan.
mattl200
Post by mattl200 » Tue Sep 04, 2007 1:18 am
a while ago had a local linatex company do them for beer money/workers slush fund
By mattl200
(my sti) had some l series ones made up but i don't have a pic of them
u do feel more vibration from the gbox though
edit: wrong pic
Post by AlpineRaven » Tue Sep 04, 2007 7:01 am
You can buy Urethane filler from car stores, I did use it to fill up on engine mounts a long time ago for a FWD car which always tore engine mounts and was fed up with it so I used Urethane to fill empty space up - lasted me 5 months till the car was write off.
You can buy a tube - would be approx $30 something - last time I bought it was 4 yrs ago.
stamp_licker
Post by stamp_licker » Tue Sep 04, 2007 1:33 pm
vincentvega wrote:lol
Nah sick of tossing $$$ at it,gunna make some up out of some nolathene shock rubbers i've got laying around if the auto stays.
stamp_licker
Post by stamp_licker » Tue Sep 04, 2007 1:34 pm
BaronVonChickenPants wrote:Maybe the engine needs a stay rod to stop it pulling forward causing the mounts to tear? Just a theory.
Jordan.
Got a stay rod in there.
Post by Gannon » Tue Sep 04, 2007 4:52 pm
Coach Bolts and blocks of Treated Pine are cheap
stamp_licker
Post by stamp_licker » Tue Sep 04, 2007 6:15 pm
LOL,cheap and nasty, got any pics?
vincentvega
Post by vincentvega » Tue Sep 04, 2007 7:38 pm
they dont break for no reason though Will.
You have a mount designed for a 200KW TT breaking behind a 100KW EJ22
something is causing this!
Chris_Rogers
Post by Chris_Rogers » Tue Sep 04, 2007 10:05 pm
stamp_licker wrote:Nah sick of tossing $$$ at it,gunna make some up out of some nolathene shock rubbers i've got laying around if the auto stays.
seems we have the same problem. mine were torn top to bottom. going to get a new set before it goes to the shop.
Audio Express
1987 HR31 Nissan skyline
1990 R32 Nissan Skyline GTS4
stamp_licker
Post by stamp_licker » Wed Sep 05, 2007 4:05 pm
vincentvega wrote:they dont break for no reason though Will.
yeah i got a few theories. they came from awrx that had beeen" used" and had killed its g/box so probably weren't the best to start with.
I can fix em i've done this L series ones before,just looking at other alternitves.
Suby Wan Kenobi
Post by Suby Wan Kenobi » Thu Sep 06, 2007 9:15 pm
i got an idea but ill need to see you about it.
The long road ahead
subanator
Post by subanator » Fri Sep 07, 2007 12:10 am
AlpineRaven wrote:You can buy Urethane filler from car stores, I did use it to fill up on engine mounts a long time ago for a FWD car which always tore engine mounts and was fed up with it so I used Urethane to fill empty space up - lasted me 5 months till the car was write off.
The product is Sikaflex, there is couple of variations of this, the contact type is what you want. Even Bunnings have some in stock, but check the use by date on the tube as they go off.
I used them on the MY gearbox mounts and last 2 years while I had it, and Subarino has used it for the same thing too.
stamp_licker
Post by stamp_licker » Fri Sep 07, 2007 4:26 pm
Suby Wan Kenobi wrote:i got an idea but ill need to see you about it.
i'm all eye's and ears.Had a look at some yesterday simple but effective design ,no chance of breaking.
yarney
Post by yarney » Sun Sep 16, 2007 9:07 pm
Hi Will Andy got some last week from an old club member Dave m put him on to them
Dave has used then for a couple of years in the super brumby he said they work real good
see Andy at the next meeting he will show them to you
Jan
Jack
Post by Jack » Sun Sep 16, 2007 9:35 pm
Jan, can you please remind me to take the Brumby to the next meeting?
Will, the mount brackets I've fitted have firmed up the gearbox a treat and I can't see them breaking easily, or wearing anytime soon. They're easy to fit too (heck, if Jan and I can fit them then anyone can). Only downside I've noticed when compared to Subaru OEM mounts is that these new ones allow slightly more noise and vibration through to the floor.
You're welcome to have a sqizz at these brackets anytime. :)
1999 Outback (some mods)
1989 Brumby (more mods)
