ea81 -ea81t
camo85
ea81 -ea81t
Post by camo85 » Mon Jul 23, 2007 7:29 pm
Whats need to change a stock ea81 motor into an ea81 turbo can it be done intake manifold and injectors can be sorted
cheers
camo
Post by steptoe » Tue Jul 24, 2007 11:43 am
that is gonna depend on if you want to replicate a Subaru factory turbo (efi) installation or just 'a conversion' using the carby, or even LPG set up.
Post by Gannon » Tue Jul 24, 2007 4:51 pm
The EA81t has different heads to the EA81 carby, as the injector bosses are in the actual heads themselves, unlike the EA82T which has the injectors in the intake.
The EA81t will also have lower comp pistons and an oil inlet and outlet port on the head for the turbo.
You would probably be better gettin a complete motor.
timmo
Post by timmo » Tue Jul 24, 2007 5:09 pm
you would also need a efi wiring loom or custom engine management setup
L series wagon EA82T (RIP)
'92 Liberty RS Turbo
GU Patrol Ute
Honda XR400R
redskin
Post by redskin » Tue Jul 24, 2007 10:49 pm
Completely different engine, Suparoo mentioned some, then there's cam, lifters, etc. etc.
Redskin
89 Brumby
EA-81T.
Post by steptoe » Tue Jul 24, 2007 10:59 pm
and a word of warning.... I started out buying a turbo crossover pipe on ebay for $18, intending to wack a turbo on my gas EA81 then my parts collection got out of hand. I now have an L series auto turbo sedan EA82T now goes !, a spare rolling shell with turbo 4WD compliance plate as well, enough bits to build another motor for my other Brumby, spare the bloody rusted out metal hoses.
Becomes very time consuming to learn and clean all the bits and get it al back together and running
Post by El_Freddo » Wed Jul 25, 2007 2:03 pm
jono wrote:and a word of warning.... I started out buying a turbo crossover pipe on ebay for $18, intending to wack a turbo on my gas EA81 then my parts collection got out of hand. I now have an L series auto turbo sedan EA82T now goes !, a spare rolling shell with turbo 4WD compliance plate as well, enough bits to build another motor for my other Brumby, spare the bloody rusted out metal hoses.
And thats the fun of it! If your keen to do it and know what its all about but still have some questions, someone will know.
Go for it, even if its a learning curve and you say you should'a gone for an EJ20G or something a little more substansial.
Jeff
Post by Jeff » Wed Jul 25, 2007 5:49 pm
I looked at a brumby today that was EA81 carb with a suck thru turbo setup with custom crossover pipe etc and the thing ran fine [no i didnt drive it] but it can obvioslly be done and it wouldnt be that hard or expensive
Post by steptoe » Wed Jul 25, 2007 7:15 pm
and after pulling my old EA81 apart this arvo in no time and heaps less parts than an EA82T I was thinking to myself "still need to turbo this baby when i replace the CACTUS middle crank bearing, heaps less parts if it breaks"
Jeff, you say suck through which also means draw through which should mean the turbo sucks the air and mixture through the carby - what sort of carby and where was it ??
Jeff
Post by Jeff » Wed Jul 25, 2007 7:48 pm
the carby looked standard and it was at yandina qld
It is for sale if anyone is interested i can put you in touch with the owner
Post by Gannon » Wed Jul 25, 2007 8:33 pm
I think this is a drawthrough setup, Homemade turbo setup
If you do drawthrough, you need to add extra seals to the compressor side of the turbo because at closed throttle, it will experience manifold vaccum, and without the seals, will suck in oil
Suby Wan Kenobi
Post by Suby Wan Kenobi » Wed Jul 25, 2007 9:40 pm
Dont stuff around with the EA81 in search of power go the EJ22 and save yourself a heap of hassle
The long road ahead
90brumby
Post by 90brumby » Wed Jul 25, 2007 9:48 pm
Suby Wan Kenobi wrote:Dont stuff around with the EA81 in search of power go the EJ22 and save yourself a heap of hassle
deffently agreed i spend like 1300 buks on a ea81 n its still hell slow
but yer its still a stock engine which is good 4 a P plater (well soon)
The New Owner Of hatchie
A 00 outback for doner car
2 door wrx being restored
littlewhiteute
Post by littlewhiteute » Sun Jun 08, 2008 2:48 pm
Suparoo wrote:I think this is a drawthrough setup, Homemade turbo setup
That's a blow through, not a draw through.
Carb is in stock location and pressurised from turbo.
Gary ;)
Post by Gannon » Sun Jun 08, 2008 5:52 pm
Woops!
It is a blow through, my mistake
In which case, you will have to pressureise the float bowl to prevent underfueling
Post by steptoe » Fri Mar 30, 2012 8:02 am
Thought this worthy of a BUMP for the youtube in post #10
