help me build an EA AWD gearbox
stinky
Post by stinky » Sat Mar 03, 2007 3:53 pm
I just picked up my ebay score of a single range 5spd full-time box, and part-time box with an full-time housing on the back and a bucket of gears and shafts. oh and an old 3.9 4spd I already have.
I know naff all about gearboxes but want to make the best gearbox I can out of the parts I got to go into the brumby. I've also got the dual-range 3.9 5spd in the brumby which could be used for 'parts' to build it up, but I'd rather use the spares that I have.
Anyone keen to help me split the boxes and build something out? Happy to pay in the usual currency of grog and food. Hell I'll even pay cash if you wanna take them away and do it for me :p
PeeJay
Post by PeeJay » Sat Mar 03, 2007 6:14 pm
I was wondering who got that :)
Post by El_Freddo » Sat Mar 10, 2007 1:18 pm
Hey stinky.
I've not done one of these jobs, but i envy you greatly. AFAIK, the gear ratio's are the same between the boxes, only difference is that the 5spd Dual Range box has the Dual Range and the 4wd selectors in the extension housing.
Now i'm sure you could with the 5spd AWD box and a 5spd Dual Range PT box create a dual range AWD box. Only problem would be locking the centre diff for 4wding, unless you could find a tight LSD to put in there like the EJ boxes. You'd use (in my mind) the bottom gear set (with the centre diff on it) to replace the one in the PT Dual Range casing, retaining the input shaft + top gearset from the PT Dual Range box. This should give you the Dual Range parts + the AWD parts. Use the AWD extension housing out the back, it will bolt straight on.
The other thing you'd have to do is make a stopper for the Low/High range selector arm so it will hold in either low or high with out you having to hold the gear stick all the time.
(I hate advertising my threads twice in one day but) check out this thread showthread.php?t=4311
There'll be some pics in there that might help you out.
