1st gear whining like straight cut - any ideas?
Posted: Sat Nov 19, 2005 1:48 pm
Finished putting my AWD gearbox into the RX last night. Went for a drive, and 1st gear whines like its straight cut (the same as reverse gear whine). The noise only comes on at about 2,000rpm which is similar to reverse gear aswell...
Now i had the gearbox apart and was checking all of the bearings for noise - all of them were in excellent condition! If anything the front diff and centre diff bearings were a little noisy, but still acceptable. I even checked every gear for noise aswell. The only thing i didnt check was the synchros - cause i didnt know how, nor have a workshop manual for the clearances. Also, the gearbox hasnt been run for over a year... Yet everything still had a layer of oil on it when i had it apart.
Does anyone have any ideas or suggestions to fix this? Could it be that the gearbox hasnt been run in enough to get the oil circulating to something? Or could it just be a worn synchro and nothing of an immediate problem?
What sort it quick fixes could i do for it? Put in some thicker oil to stick to the bearings better? or thinner oil to get to the bearings easier? Or some kind of friction modifying additive?
edit: although it is a very cool noise, i am selling this car asap so i cant really keep the noise
Otherwise i would!
Cheers!!!
-Adam
Cheers!!!
-Adam
