Throttle Pos sensor
Throttle Pos sensor
I noticed the other day my wolf3d is showing the TPOS at 106 regardless of the actual position of my accelerator. Anyone know if the TPOS sensor is an easily replacable item on an ea81t ?
The ea81t uses the same efi system as the 85-86 ea82t motors (3plug ecu).
So a throttle position sensor off any 3plug ea82t should do the trick.
pretty sure the standard TPS is a switch for idle and Wide Open Throttle, not a variable sensor.
Yours may have been changed if your runnning an aftermarket ecu. I turned mine into a varible sensor for the Injec ems
Check the wiring as well.
'97 Outback - almost back to grandma spec operating condition.
"A day is never more than what you make of it."
There are 2 sensors on the throttlebody
One is a throttle position sensor ( a variable resistor)
The other is a throttle switch (a 2 position switch, has contacts for idle and WOT)
Found the original tps I removed from my ea81t, only has idle and WOT switch, part no. A22-610-970. If this is what you need you can have it for whatever postage costs.
Have an s2 ea82t in the shed that is as you descibed suparoo.
Is your wolf set-up to use TPS as transient enrichment and load by MAP ? look at you settings before you go correcting the idle switch...it may not even use it !
I`ve seen many quick and dirty Wolf installs where they just use internal map for transient and load(even seen no water temp connected ahahaha). So so ugly !
What version wolf is it ?
OS
OS
MY05 GT-STI DCCD 6spd 13.88at98.7
88 FJ62 Cruiser-5.0ChevTPI TT,6psi,Hi6,044,Wolf3dV4,FMIC
it's a wolf-3d.. no idea if it's set up to use it or not, but I know it reports the result to the LCD screen!
might be worth just taking it to somebody who knows the things and get them to take care of it too me.
Is it V3 or V4 ?
You can inspect the set-up thru the hand controller.....V3 you might need to inspect the dip switches in the box, V4 use a laptop.
Best advice I ever got regarding my V3.1 Wolf3d was "throw that pos in the bin !" I very much apreciated the honesty from the dealer !...Steve said the same thing more or less when I spoke to him too lol !
You can upgrade from V3 - V4 for ~$600.....ask wolf direct if you just get funny looks from local dealer
Its worth the money to upgrade for the greater functionality and quality of the later unit.....harness only needs to be re-pinned a little, plugs are the same.
Controller will display it if used or not....its smart like that
It really is imperitive that you have transient load sensed by TPS.....load can be by Speed density(MAP) or MAF......but if it can`t tell transient acurately&quickly it will be dull and pigish !
OS
PS: do you have the config on laptop/computer...... send it to me and I should be able to tell whats what
OS
Hmm no I don't, but I think it came with a little unit that can be plugged into a parallel port of a PC to read. Will check it out.
Also will take a serial cable for a laptop, but appears to be a custom pinout and nobody seems interested in selling one.
OK on that model wolf3d the load sensing settings are set with the DIP switches inside the case, switch 5 and 6, .....for MAP load and TPS enrichment 5 should be off 6 should be on.
There are various combinations.... can you remove the cover and tell me what all the switches are set to ?
OS
OS
- SCOOBIDOO
wolf interface cable
I have a diagram of the pinouts and plugs required to make this cable..i made one for my self due to the same ..not able to get one... and it works fine..stinky wrote:Hmm no I don't, but I think it came with a little unit that can be plugged into a parallel port of a PC to read. Will check it out.
and your 106 throttle is correct in what it is telling you..that is max open.and the wolf will think you have your foot to the floor at all times until you fit a potenziometer type tps...
SCOOBIDOO wrote:I have a diagram of the pinouts and plugs required to make this cable..i made one for my self due to the same ..not able to get one... and it works fine..
ooooh pls send to me! I'd kill for that!!
I'm 99.99% sure it used to show a graduating TPOS, so I think the sensor is stuffed.
- SCOOBIDOO
Got an email address then? or can i post a picture file here?
Good luck with that... What software you going to use ?
AFAIK the cable for the V3 wolf your attempting to build is for reading the mem cart via a paralell port.....I don`t think wolf made pc-wolf sw for V3. You dump the map to cart and them read/write cart via 25 pin paralel
I have said cable(came with my V3) and a mem cart I don`t see a need for....make me an offer if your interested.
OS
OS
You know what, I think I got the version # wrong. I think it must be in the 4's somewhere, I was looking over the manual yesterday and the mapping was all done via the handset, and is set to TPS btw.
