AWD BOX
dr650
AWD BOX
Post by dr650 » Sun Nov 06, 2005 9:00 pm
How can you tell if the l series and an awd box or part time 4wd box are the numbers different??? thanks for any help
Shorty
Post by Shorty » Sun Nov 06, 2005 10:21 pm
in the part time it will have a lever to select 4wd if no lever then u have awd
hehe and that is coming from a girl :D
Take Care
Shorty
Fang
Post by Fang » Mon Nov 07, 2005 5:26 am
There are a few things you can look for
The gold vaccuum diaphragm -: Used to Lock the Centre Diff. Dont look for this alone - Single Range P/T 4WD boxes had this too
Count the splines on the front drive output - there should be 25 not 23. Does not necessarily means its AWD tho - 25 splines just means its an RX box. All L Series AWD boxes have 25 splines.
The definiatave way I told was by turning the input shaft. I selected the rod/levers in all positions - and the 3 output shafts always turned. If you have 25 splines and the diaphragm - then its AWD.
Shorty is correct - there should be no rod for selecting 4WD - but if its dual range there will be a rod for Hi/Lo Range selection. If it has a rod, it should only have 2 positions - not 3. 3 positions is for Part Time 4WD
I believe the external case is the same for AWD and Part Time 4WD.
Maybe someone else can hook you with numbers, etc
Ben
Post by Ben » Mon Nov 07, 2005 9:00 am
Easiest way is to look for the difflock - on the drivers side of the box near the mount bracket there is a lever that is actuated by the cable going to the vacuum diaphragm, if you have that lever it's an L series awd box.
Also, next to a part time box, the centre diff housing at the back is *clearly* bigger and different shaped.
Please watch before posting!
Ben
Post by Ben » Mon Nov 07, 2005 9:02 am
Shorty wrote:in the part time it will have a lever to select 4wd if no lever then u have awd
Take Care
Shorty
If its a d/r awd box you still have the lever to select hi/low, it still goes through the box the same as the 4wd selector on the part time box, only instead of engaging 4wd (under the gold inspection plate) it just passes through.
Fang
Post by Fang » Mon Nov 07, 2005 10:38 am
MechaWagon wrote:Easiest way is to look for the difflock - on the drivers side of the box near the mount bracket there is a lever that is actuated by the cable going to the vacuum diaphragm, if you have that lever it's an L series awd box.
Correct me if I am wrong - but wouldnt a single range 4WD box have the same setup??
Ben
Post by Ben » Mon Nov 07, 2005 2:35 pm
Nope, the entry point for the selector that operates the difflock is nowhere near the 4wd actuator. The difflock one is near the bottom.
Fang
Post by Fang » Mon Nov 07, 2005 5:06 pm
Okay - thanks for clarifying that.
dr650
Post by dr650 » Tue Nov 08, 2005 9:16 pm
Thanks for your help now i can tell the difference..
Post by AlpineRaven » Sun Nov 13, 2005 7:10 pm
Was there any EA82 AWD boxes (not from Liberty) that was sold in Australia?
As far I know from what I heard that AWD were not sold in Aus for EA82s. EJ series AWD boxes does not fit on EA82 engine correct?
Fang
Post by Fang » Sun Nov 13, 2005 7:31 pm
Correct AlpineRaven - the Full Time 4WD box (AWD) was never sold in L Series in Australia.
Not sure about the EJ adaptation...
BaronVonChickenPants
Post by BaronVonChickenPants » Sun Nov 13, 2005 10:10 pm
The EJ boxes will not directly bolt up to an EA8x engine, you'll need to use an adaptor plate, as well as modified CV and tail shafts.
If you're going to all that effort you might as well drop an EJ engine in there while you're at it, then you only need to modify the shafts.
Jordan.
Guest
Post by Guest » Sun Nov 13, 2005 10:20 pm
Fang wrote:the Full Time 4WD box (AWD) was never sold in L Series in Australia.
What about the L-Series turbo automatics? I think the later ones came Aus-delivered AWD Automatic. I'm also thinking Vortex, but I'm not sure if any were from Australian dealers.
I'm probably totally wrong though, just a thought.
adam_rxturbo
Post by adam_rxturbo » Sat Nov 19, 2005 1:30 pm
i've got a awd single range centre locking box :D was for sale for $300 but you're all too slow and its now in my car :lol: I think they came out of an imported L series RX turbo or something...
And yes the end housing is longer and a different shape.
-Adam
Fang
Post by Fang » Sat Nov 19, 2005 4:39 pm
Who's "you all", fella?? :D
I have a dual range version AWD going into my L in a shortly.
wagonist
Post by wagonist » Sat Nov 19, 2005 11:42 pm
Just to be a technical bastard, but the term Subaru used for the AWD L series boxes is "Full-Time 4wd".
I personally thin kwe should stick to that because it separates the mechanical centre diff boxes from the viscous EJ AWD type.
Weren't the 4wd Vortexes single range full-time 4wd?
Current rides:
JDM GTII Touring wagon
Previous rides:
96 Toyota Caldina wagon
Fang
Post by Fang » Sun Nov 20, 2005 7:47 am
EXACTLY RIGHT! - I was using that term coz it simplified things. Sounded like we were talking bout two different boxes
