91 liberty auto
91 liberty auto
I have a 91 liberty gx wagon auto and the autobox for some reason wont change into 4 th gear or overdrive
i can change manualy 1,2,3
does anyone have some clues ?
the sub sits dead in the driveway as i cant go over 50klms
regards
silverback
regards
silverback
- Suby Wan Kenobi
- Suby Wan Kenobi
The main sensor is on the back of the dash but if it is a problem the Check engine light will be coming on and it will register as an error. If its the one at the rear of the gearbox the TCU should register it as an arror and the power light on the dash should flash.
The auto trans fluid is still red?
The long road ahead
The long road ahead
codes
I went to the test mode under the dash and and pluged in the apt wires and one of the codes was a { read mode} (seven flashes and then short pause then seven flashes again )
In the {D check mode} i had (three flashes a short pause followed by three flashes again ) I dont recognise the fault area codes any clues ?
