Early MY fuel pump
Early MY fuel pump
This unit as per the link looks to be the same as my original fuel pump.
My original pump died a few years ago and I sourced one from NZ which was similar to the original but is pretty noisy.
Wouldn't mind fitting an OEM pump to get back to standard.
This unit is being listed as suiting a 1600 engine.
I have asked the seller for OEM part numbers and anything to say it will suit an EA81 but they have replied they have no info but if could fit.
http://www.ebay.com.au/itm/141959416522 ... Tags=bu=bu
Anyone have any info on if this is suitable for an EA81 ?
I have another option.
Years ago I pulled a fuel pump out of a later model Brumby (mounts in the rear up near the tank), pump, wiring to the immediate connector (plus a bit including both parts of the connector) and the pump mounting plate that connects it onto the car body.
Trouble is, I cant recall exactly where it mounts under the rear at the rear of the car.
Anyone able to take some photos of where the pump mounts ?
Dont know if the early and later MY's/Brumby's have the same chassis design or not but I can have a look at this option anyway.
- TOONGA
This is from Phiz's leone conversion http://offroadingsubarus.com/83-subaru- ... onversion/
It show where the brumby style pump would live
