ea81 tick at idle
- pitscars007
ea81 tick at idle
Hi guys - I have an ea81 that ticks pretty loudly at idle - it seems to be coming from the camshaft - tick goes away at about 1200 rpm then comes back at idle - it was REALLY bad when I got the car but after I adjusted the valve clearances it improved a lot - its a "GEM" recon motor that sounds perfect at revs but goes clackity clackity at idle - I would hope a recon motor would have got a new oil pump ? ---- oil pressure issue ? -- bad pushrod ? bad lifter ? had it running with the rocker covers off and theres plenty of oil getting to every rocker - oil light goes out instantly at startup - any ideas ? Cheers
- Proton mouse
- pitscars007
I'd be looking into why it's moving that much - there must be some sort of spacer that's missing or something that holds it in place needs to be checked out to make sure it's still good or find out if it's loose or needs adjusting etc.
I haven't got an exploded view of the ea81 handy to check it out. There might be a manual in the download section on the forum which can be handy. Toonga also has a link to some good factory manuals too
- pitscars007
- pitscars007
Thanks for the replies and the offer but the motor was in a Brumby I bought some time ago for $250 - at least I have a couple of good heads - and I suppose it is possible to put a new cam and lifters into it at some stage - I have a few ea81s lying around so for now I will make one good motor to go into a nice Brumby I'm buying with a cooked engine - its just got a bit harder than I had hoped - Cheers
- pitscars007
- pitscars007
- Bantum
Camshafted ...
Neat video worth watching :
Cheers, Bantum ...
Yep, sorry you're not going to get it off without disassembly first & most likely it will need a press too ...
Cheers, Bantum ...
