help! my timing belt idler pulleys are different
gazcull
Post by gazcull » Thu Nov 06, 2014 7:15 pm
hi just rebuilt the top end of my ej25d engine from my 97 outback and was just in the process of refitting the timing belt , i brought a dayco timing belt kit from ebay with the pulleys, the number of the kit was ktba 161. ive just noticed that one of the idler pulleys is a little different than the other, the part number on the packing seems correct, its k126 , the new one has a ridge around it, is a little narrower but exactly the same width, is it correct? really wanna make sure before fitting, i can try adding a pic , cheers for any help
Post by TOONGA » Thu Nov 06, 2014 7:26 pm
A picture would help, I noticed on Ebay USA that some kits (for the EJ25) won't fit EJ25 engines with a build date after 3/97.
Have you contacted the seller?
tambox
Post by tambox » Thu Nov 06, 2014 7:33 pm
Is the belt the same number of teeth?
L serious, still.
gazcull
Post by gazcull » Thu Nov 06, 2014 8:51 pm
yeah the belt is the same
Post by TOONGA » Fri Nov 07, 2014 7:50 pm
You may have been given an idler for the SOHC EJ25, only one I can think of that has a lip on the idler.
