Head gasket/welch plugs
Hi guys, looks like one of my head gaskets is gone or a whelch plug has shit itself. I have water in my oil, bubbling rad, white smoke out the exhaust and a strange rattle/tap in my engine. It's a EA82T, exactly what am I need to get to change the head gaskets apart from the head and inlet gaskets. Never worked on these engines, I've done plenty of Holden straight sixes which are easy compared to the EA82T.
Thanks in advance
Canny
Thanks in advance
Canny
Hopefully it is just head gaskets or a welch plug! The EA82T is quite notorious for cracked heads - especially if they are overheated a few times.
I would contact Frog as there are quite a number of seals you might as well replace while doing the heads. The reinforced O rings for both the cam cases and the seals for the camshafts would be a start.
Old Boxer Tricks
1980 Brumby
1978 4WD Station Wagon
1974 DL Sedan
1974 GSR Coupe
1980 Brumby
1974 DL Sedan
1974 GSR Coupe
Just drove a clapped out ea82t from Melbourne to alice spring with the same symptoms, was also running very hot when left Melbourne, by the time I got to Nhill car was running great.placed resone???I think it was called into radiator, it is copper block seal. also tapping noise(lifters due to water in oil), this has also gone. got hot 400km from Alice removed thermostat as it stuck from this product, then ran cool again.
try this product as it proved to work well over thousands of km's, allows time to save up for a rebuild.
Glad to hear you made it - I'd been wondering too!pzs wrote:Just drove a clapped out ea82t from Melbourne to alice spring with the same symptoms,
Canny, I've worked on old holden red 6's as well - then went to the EA82. If you can work on a holden red, can learn some new things and you're observant I reckon you'll be fine with the EA82...
SCA degreaser first, under, over, beside it. Wash and polish exterior ....
And before you pull this beast apart - get the timing belt covers off to familiarise youself with position of dizzy, rotor in relation to timing marks on flywheel, the cam wheels timing marks and holes, noting one is up, while other is down. Take pics and save them to something safe like [email protected] so you can retrieve them.
