E81 difference between hyd and solid lifter engines?
Hi all,
Have just bought a 1990 Brumby for a run about and treating it to a bit of a birthday...
Upon pulling the (black) rocker covers off I've found the valves to have no clearance, so I suspect that it has hydraulic lifters but what is the easiest way to check?
The engine has been re-cond at some point so it has no stickers on the covers and also does not have lock tabs on the rocker gear?
T.I.A for your help
T.I.A for your help
Hi and Welcome Rainoski
If it doesn't have locking tabs then I'd say it's solid lifters. I'd adjust them to spec and then run the engine. You'll know from there if they hydraulic.
If they are black rocker covers with the little sticker that states not to adjust then yes
Depends on how good your pressure washer is and it was in ingrish
