Fuel
If you have a turbo vortex, run it on 98 only.
The engine would have been designed for 95, but with 98 in in, you should be able to advance the timing by a degree or 2 and get a few more horsepower out of it
- TOONGA
I run my vortex on 91 mind you I have an EJ22 in her and a computer that will let me run on 91
But for the turbo use premium
http://www.youtube.com/watch?v=dceB3SKBw9w
As these car were designed and built to run 100RON fuel in Japan, then 100RON fuel from United Fuels is your best option but I'm not convinced that the ethanol in it is any good for Subaru engines. I've seen many different reports. I prefer to use BP Ultimate 98 in my cars. I find they perform so much better and even get more kms per tank full.
If you are talking about using it in your Vortex, then I'd return with higher octane fuel and you'll get the most out of your engine.
I ran E10 95 (only premium available) in my EA82T for 2 years an have run E10 91 in my Outback for over 4 with no issues
- Silverbullet
So am I just wasting primo fuel by filling my Brum with 98 every week?
Only a recent change, but the engine runs so so much better with it. More power in every rev range and no more pinging full stop. It's worth the extra money to feel the extra go every time I put my foot down in top gear
The dentist says sugar is no good for your teeth I say therefore it is no good for your engine. Ethanol is pure sugar end of story. It will eat everything like it eats teeth. You can't convince me to put that stuff anywhere near a vehicle I own. I came to OZ from Zimbabwe a long time ago and saw what government mandated ethanol ratio's did to perfectly good engines there. My advice is DON'T do it
List of cars that can use ethanol blends
http://www.fcai.com.au/environment/can- ... nd-petrol-
in short "not good for Subies" then ?Venom wrote:List of cars that can use ethanol blends
That was my own conclusion after I used it just once. Then I went back to 95 or higher.
1985 L Wagon DL. Carb. EA82. Stock.
Posted verbatim from the link "As a solvent, ethanol attacks both the metallic and rubber based fuels lines, and other fuel system components.
Ethanol also has an affinity to water that can result in corrosion of fuel tanks and fuel lines. Rust resulting from this corrosion can ultimately block the fuel supply rendering the engine inoperable. Water in the fuel system can also result in the engine hesitating and running roughly."
I rest my case
I rest my case
I use 100 from United in my JDM WRX engine as that is what they are designed for. Im not sure it offers any benefit at all over BP98 however it is much cheaper also so win win.
I found the difference from something like caltex 91 - BP 98 was enormous when I had an NA. At least a 15% increase to fuel economy and decent performance boost.
I have used E10 in my Forester just the once, it ran like a sick dog at the track, never again will i put E10 in a car I own.
My mate has a 2013 Honda CRV 4WD VTi-L + ADAS 2.4L i-VTEC, he put E10 in 2 weeks ago and it was returning 13 L/100k around town where on 95RON he was getting 9.5 L/100k, he too has vowed & declared never to use E10 again.
He used to use E10 in his Subaru Imprezza before he sold it and it jerked and shuddered badly.
Peter
