Gearbox Codes
ozbrumby
Gearbox Codes
Post by ozbrumby » Mon Nov 04, 2013 10:53 am
Heya folks
I am have a Brumby with the following gearbox code
TY752VD1AA from searches I discover that it is from a 1990 2.0L Liberty and is an AWD box. I need a new box bad as the noise it makes it is getting worse.
I have a lead on another AWD box on Gumtree and its code is TY752XH2AA So using same chart i found its a 1991 2.2L Liberty but I cant find any clues what the XH stands for and more importantly what the diff ratio is
I am fairly sure it will be the 4.11 but dont want to buy a box I cant use or then have to swap out diff as my rear diff has just been rebuilt.
Can anyone help with a box or help with the codes.
Peter
STiAMV
Post by STiAMV » Mon Nov 04, 2013 4:26 pm
Manual you found it comes with a low near, you will have to bring in the cabin on lever. And yes it has a gear 4,111
Subaru Forester EJ201 МТх2 JP 2001.-there are
Subaru Impreza EL154 SS EU 2008-there are
Subaru BRAT ЕА81 MTx2 EU 1989.-there are
ozbrumby
Post by ozbrumby » Mon Nov 04, 2013 6:10 pm
Thanx for that...no good need single range
Where can I find the breakdown of the codes.
I have looked everywhere and cant find quite the right table
I did find codes but not telling me the whole story
STiAMV wrote:Manual you found it comes with a low near, you will have to bring in the cabin on lever. And yes it has a gear 4,111
Post by RSR 555 » Mon Nov 04, 2013 8:22 pm
Both the 1990 and 1991 should be 3.9 ratio
ozbrumby
Post by ozbrumby » Mon Nov 04, 2013 8:42 pm
Goodness me Paul
So many different opinions re the final drive.
I would be happier if it was a 3.9 as I drive on main highway into work every morning and the 3.9 is a taller gear for cruise.
There must be table somewhere stating the obvious....anyone
Peter
RSR 555 wrote:Both the 1990 and 1991 should be 3.9 ratio
Post by RSR 555 » Mon Nov 04, 2013 9:46 pm
There was no standard for this other than what Subaru keep on the VIN tags but now knowing yours is from an import VZ Legacy then most likely a 4.11
I'll have a look at what I have and if there isn't anything in my collection, I'll see what else I can find in WA. I know you don't really want a dual range but I know I have a Gen2 Liberty dual range box and diff which I've been told the Gen2 have 3.7 ratio. You could just fit this without fitting the d/r cable and this would then just be a single range AWD box.
Post by El_Freddo » Mon Nov 04, 2013 11:04 pm
RSR 555 wrote: I have a Gen2 Liberty dual range box and diff which I've been told the Gen2 have 3.7 ratio.
That's what I've always found in the Gen 2s while in the parts yards ;)
