timing belt kit for 93 rs turbo
please help i need a new timing belt and the idlers for my 93 rs turbo motor , it was a jap import and the only numbers i can find are the ej2o , have checked all over on the internet and it doesn't seem to be listed anywhere, im pretty sure the belt has 281 teeth and is 30mm wide , that's the only information i seem to be able to dig up, please help really wanna get this sorted, cheers
If it's still the original EJ20 engine then it will be the same as the early WRX kit. Both RS and early WRX use the EJ20G engine. If the engine has been changed at any point then you'll need to look at the Timing Belt Tensioner. If it has 2x bolts holding a long skinner tensioner then it will be the early one. If the tensioner is help in by 1x bolt (and looks like it pivots off that bolt) then it will be the later model.
Early model kit...
http://www.ebay.com.au/itm/NEW-OEM-Suba ... 2c6add3318
Later model kit...
http://www.ebay.com.au/itm/Subaru-WRX-N ... 3cb318264b
Early model kit...
Later model kit...
