5 speed for EA81
ozbrumby
5 speed for EA81
Post by ozbrumby » Fri Sep 20, 2013 6:49 pm
Heya guys
can someone confirm if the 5 speed box out of a 1991 fuel injected Leone (EA82.?) will fit up to an EA81 Brumby.
I have a lead on a complete 91 Leone
Peter
Post by TOONGA » Fri Sep 20, 2013 7:06 pm
Yes it will but you may have to use the clutch and flywheel from the 91 Leone and put a spacer on the stater motor.
Steptoe to confirm the spacer?
sublime
Post by sublime » Fri Sep 20, 2013 7:10 pm
You will have to change the DOJs on the CV shafts too I think... From memory the fuel injected Leone had the 25 spline axles like the turbos. Your Brumby will only have 23...
Old Boxer Tricks
1980 Brumby
1978 4WD Station Wagon
1974 DL Sedan
1974 GSR Coupe
555Ron
Post by 555Ron » Fri Sep 20, 2013 7:14 pm
The DOJ side of the driveshaft will have a different spline count to those on the Brumby driveshaft. You need the put the L series fuel injected joints onto the brumby length driveshaft. A carbed L series box will have the same splines as the brumby...
Oh, I was beaten to it, ohh well
- Rhys
91 Brumby
ozbrumby
Post by ozbrumby » Fri Sep 20, 2013 9:58 pm
just had a thought
I don't think its is a 4wd unfortunately
It is a sedan not a 4wd wagon....wont work will it ..???
Post by steptoe » Sat Sep 21, 2013 7:48 am
efi EA82 FWD sedan non turbo would be a Leone Royale ? Box should fit but restrict you to FWD. I know turbo FWD EA82 boxes are 25 spline stubs out of the Vortex. Good luck to anyone able to pull an EA82 L Series CV shafts apart DOJ or CV end. Funny, I only had trouble after I read that they are not meant to ever come off again ! :(
ozbrumby
Post by ozbrumby » Sat Sep 21, 2013 8:23 am
steptoe wrote:efi EA82 FWD sedan non turbo would be a Leone Royale ? Box should fit but restrict you to FWD. I know turbo FWD EA82 boxes are 25 spline stubs out of the Vortex. Good luck to anyone able to pull an EA82 L Series CV shafts apart DOJ or CV end. Funny, I only had trouble after I read that they are not meant to ever come off again ! :(
Steptoe
I don't understand what DOJ is I get the CV end is gearbox side of shaft
DOJ is it the hub end..??
and are the shafts meant to come apart at all and why was it hard to split.
I thought about only using the front WD but am not to sure.
Not that it will ever really see the bush but its sorta there and dosent seem right pulling the tailshaft out of it.
Post by steptoe » Sat Sep 21, 2013 11:22 am
Vice versa. EA81 shafts are easy enough. Reckon I got a few EA82 DOJs off before I read that they are not serviceable/pull apartable. The best CV shafts I have are a pair I made up out of bits I had all over the shed floor, inspected and assembled in a desperate measure. Certain some were EA82 DOJ.
Last lot of L Series I tried to pull apart - not willing at all.
FWD Brumby would be rude. Spline count on whatever you find is needed to ensure no last minute dRAMAS.
