4 speed gearbox (gear 3.9) and EJ254
STiAMV
Post by STiAMV » Wed Sep 11, 2013 5:09 am
The question is what is. From then use the clutch kit?
Subaru Forester EJ201 МТх2 JP 2001.-there are
Subaru Impreza EL154 SS EU 2008-there are
Subaru BRAT ЕА81 MTx2 EU 1989.-there are
Post by steptoe » Wed Sep 11, 2013 7:24 am
a link for an adapter plate between MY 4 speed and an EJ25 ? Any links ? The MY 4 speed gearbox is not strong enough for EJ25 power output.
STiAMV
Post by STiAMV » Wed Sep 11, 2013 7:27 pm
steptoe wrote:a link for an adapter plate between MY 4 speed and an EJ25 ? Any links ? The MY 4 speed gearbox is not strong enough for EJ25 power output.
I'm still looking for a better way to combine the EJ254 and 4-speed transmission, the adapter plate to make no problem, but as I understand it is better to set the 5-speed gearbox for the EJ254?! then begs the question of what to look for manual transmission vehicles to stay home or cardan shaft drive have to put with outboard bearings?
STiAMV
Post by STiAMV » Tue Oct 15, 2013 5:04 am
someone tell me what a manual transmission TW70F8E1-DU? how many speeds, what gear ratio?
Post by RSR 555 » Tue Oct 15, 2013 10:22 am
The 4 speed will survive behind the EJ25 SOHC engine without any issues. I'f got 2 customers that have them and never had any issues with the gearbox.
If you're going to make the adaptor plate then I would suggest you make it from no less than 12mm thinkness. I prefer to use 13mm as it's easier to come by and it also gives clearance for the flywheel away from the starter motor.
Speaking of flywheel, I would use the 4 speed flywheel but make sure it's the 9"/225mm (not the 8"/200mm one) and redrill the bolting pattern to match the EJ crank. I would also use the 225mm clutch setup from the 4 speed, so everything matches the gearbox.
If you want to go the 5 speed you'll need to do a lot of work to make it fit, i.e. crossmembers, tailshaft modification, gear linkage modification, etc...
Post by AndrewT » Tue Oct 15, 2013 12:05 pm
I ran an EJ22 on a 4spd, survived fine and it got an absolute belting (in WackyBug) but I guess we didn't run it over a few long period though.
In my experience, always best to use the clutch/flywheel which matches the gearbox.
STiAMV
Post by STiAMV » Tue Oct 15, 2013 3:18 pm
Thank you for such a detailed and open advice, but I already like you on the forum and on the resources many reports I saw and read, the work plan drawn up.* P, C, and that's about 4 speed gearbox and EJ25, this useful information, then 4 Manual survive! cheer.
we have the experience to install a 5-speed gearbox on the Forester 2001, Manual of Leone 2WD/4WD/4WDLOW, put a 15mm adapter plate, the machine is now on the go! http://myforester.ru/topic14846.html
RSR 555 wrote:The 4 speed will survive behind the EJ25 SOHC engine without any issues. I'f got 2 customers that have them and never had any issues with the gearbox.
STiAMV
Post by STiAMV » Tue Oct 15, 2013 3:25 pm
Guys, I am now interested in the question: line manual transmission, which I wrote above, as she speeds and what gear ratio? At the moment, this Manual is on my BRAT
Post by RSR 555 » Wed Oct 16, 2013 12:00 am
You will be very lucky if anyone answers your question as this number is not a recognized number for a transmission by Subaru Australia
STiAMV
Post by STiAMV » Wed Oct 16, 2013 12:55 am
if only friend from America here, there, maybe it's their designation manual transmission? and if I'm lucky)))
RSR 555 wrote:You will be very lucky if anyone answers your question as this number is not a recognized number for a transmission by Subaru Australia
Post by RSR 555 » Wed Oct 16, 2013 1:40 pm
Maybe you can post up a picture of the gearbox for us to see? Even a close up picture of the 'TW' number might also help?
As for the ratio, turn the gearbox upside down and remove the drain plug. Make a paint mark on one of the crown wheel teeth, then rotate the front diff (using the front drive shaft stubs) and count the teeth on the crown wheel.
Please report back with teeth count and pictures :)
STiAMV
Post by STiAMV » Thu Oct 17, 2013 4:40 am
How to find out the gear ratio I do not know where the oil drain plug
I wanted to ease the job))) after learning the information in the book, take a picture of the box on the top and bottom,
Well, for one do video switching Manual
Rear differential 3.7 , part number 722011012
RSR 555 wrote:Maybe you can post up a picture of the gearbox for us to see? Even a close up picture of the 'TW' number might also help?
Post by RSR 555 » Thu Oct 17, 2013 8:37 pm
The drain plug is at the bottom of the gearbox. You'll need to drain any oil first. You will need to check this before putting in the car. The diff number you list is a 3.7, so if your gearbox is 3.9 then it will drive like crap in 4WD.
Are you unable to take pictures of your gearbox?
The only other option I see for you (if you're still not sure) is to make a post on USMB.
Post by El_Freddo » Thu Oct 17, 2013 8:45 pm
STiAMV wrote:if only friend from America here, there, maybe it's their designation manual transmission? and if I'm lucky)))
RSR 555 wrote:The only other option I see for you (if you're still not sure) is to make a post on USMB.
Exactly what I was thinking!
USMB ;)
STiAMV
Post by STiAMV » Thu Oct 17, 2013 11:15 pm
RSR 555 wrote:The drain plug is at the bottom of the gearbox. You'll need to drain any oil first. You will need to check this before putting in the car. The diff number you list is a 3.7, so if your gearbox is 3.9 then it will drive like crap in 4WD.
photos done today and took video switching gears, I can just put all tomorrow night, forgot the camera at a garage in the BRAT
Title of the topic is no longer relevant, above already answered (4 speed gearbox stand EJ254), I have a second manual transmission and rear diffirentsial whose gear ratio is 3.9
Manual transmission, which I gave TW70F8E1-DU is now on the machine.
Post by RSR 555 » Fri Oct 18, 2013 9:51 am
I'm officially confused.. you'll need to start a new thread if you are talking different gearboxes. Sorry but for me it's hard to understand because of the langauge differences.
STiAMV
Post by STiAMV » Sat Oct 19, 2013 1:18 am
I'm sorry, do not speak English, ideally, Google helps)))
RSR 555 wrote:I'm officially confused.. you'll need to start a new thread if you are talking different gearboxes. Sorry but for me it's hard to understand because of the langauge differences.
STiAMV
Post by STiAMV » Sat Oct 19, 2013 1:23 am
new topic will not create, does not change the fact.
took a photo and video
only photo I saw that I did not finish a couple of characters))) No. MT TW70F8E1A3-DU
connecting the rear axle arm
rear differential
video switching speeds are 5, but I've never seen that on the BRAT was a 5-speed?!
video without comments)))
http://www.youtube.com/watch?v=UhJu6gSd ... e=youtu.be
Post by RSR 555 » Sat Oct 19, 2013 9:04 am
Ok.. no worries. We try and work throught this.
From the pictures, I can see that this a 4 speed dual range EA81 gearbox. I'm not aware or have ever seen a 5 speed dual range with this sort gearbox casings. As I've rebuilt many of these gearboxes, I cannot see how they could fit the 5th gearset in them. There was a 5 speed available for the EA81 but it was only available in 2WD.
So, with this new transmission code, I believe your gearbox to have the following ratios...
1st 3.666
2nd 2.157
3rd 1.266
4th .885
Rev 4.100
Low 1.462
Final 3.7
Post by NachaLuva » Sat Oct 19, 2013 11:01 am
STiAMV wrote:I'm sorry, do not speak English, ideally, Google helps)))
You're doing fine :mrgreen:
Well, it sure is a 5 speed ;) Is it the original gearbox or do you think its been replaced at some time?
