EJ Headgasket question
G'day all,
I'm wondering if the EJ engines, early series 1 & or 2's SOHC units can get a leak that's not easy to detect.
I'm after information and other's experience about this as I've just found my radiator in Ruby Scoo to be super low - admittedly I haven't checked it in ages and there is a little weeping at the thermo fan temp switch that I can't resolve, but I'm a little suspect about it.
I've been lucky so far as this particular unit has been up to 121 degrees working hard in the sand, real slow stuff; frozen (wrong coolant!) and boiled at least one time since then two years ago. Still pulls like a trojan.
If there is a possibility of a small leak I'd rather know about it and deal with it before there are other issues and extra cost to deal with - head shaving etc. I'd also like to know so I can keep an eye on things on the next trip as I won't have the time to deal with it before we leave.
- TOONGA
if they are the original headgaskets, there is a chance they are weeping into the cylinder or down the side between thehead and the engine at the back.
an engine sealing agent like silver seal or ... shudder chemiweld can stop the problem.
I found a product whose name I have forgotten that is copper in a suspended solution that I used with great sucess to seal a small leak in my brumby radiator.
getting heads checked and faced is always a good idea when doing head gaskets, unless you do it on the cheap and use form a gasket 515 from locktite
All looks good gentlemen. I checked it yesterday and no leaking from between the head and block, but this doesn't rule out an internal HG leak. I did find my radiator has developed a leak that looks like it evaporates before it makes it to the ground
I might give that copper seal stuff a go.
I've also got black crud under the radiator cap. Dunno what that is - anyone know?
She still purrs at idle, doesn't miss or lack any pull through he rev range. I guess a compression check would show up something...
- TOONGA
yeah it fixed a similar small leak I had with no blocking of the cores or head channelsEl_Freddo wrote:All looks good gentlemen. I checked it yesterday and no leaking from between the head and block, but this doesn't rule out an internal HG leak. I did find my radiator has developed a leak that looks like it evaporates before it makes it to the groundI might give that copper seal stuff a go.
uhh oh ... does it feel like grease?El_Freddo wrote: I've also got black crud under the radiator cap. Dunno what that is - anyone know?
have you had a previous engine with a head gasket let go on that radiator and heater core?
my vortex had this under the radiator cap a little while ago I was convinced I had a blown head gasket, then I remembered I never flushed the heater core when I got the car. the previous engine (EA82) had a massive gasket leak into the engine and a small one into the cooling. hence the goop under the cap
yep a compression check and the CO2 testEl_Freddo wrote: She still purrs at idle, doesn't miss or lack any pull through he rev range. I guess a compression check would show up something...
good luck with it Bennie
Thanks Gents!
Plan is to do a flush tomorrow, then refill with some clean water and the sealant, which is actually a glass pack.
Then go through that process, flush and refill with demineralised water and my Techaloy anti freeze anti boil.
Then I'll start saving for a new radiator and start gathering the parts for the head gasket work...
Hopefully this sealant will do the job on the radiator for this trip, that's the main thing!
