EA81 gearbox lube
Cliff R
EA81 gearbox lube
Post by Cliff R » Thu Jun 06, 2013 5:53 pm
The manual states to use SAE80W-90 for the EA81 4WD, 4 speed gearbox.
This is for the gearbox and the front diff.
Anyone got a favourite brand they find gives them a better shift change and maybe a different viscosity other than the 80W-90.
Or just stick with this.
This is very embarrassing but I don't recall ever changing the MY gearbox oil since I put the box into the car in 2001 :oops:
Post by steptoe » Thu Jun 06, 2013 6:05 pm
Sad thing is many manual boxes go through life with what they left the factory with !
I'd just go the usual and add some Nulon G70 for good measure
tambox
Post by tambox » Thu Jun 06, 2013 9:40 pm
Even more rear diffs go through life with factory oil, don't forget to do that one as well.
L serious, still.
Cliff R
Post by Cliff R » Fri Jun 07, 2013 5:53 am
tambox wrote:Even more rear diffs go through life with factory oil, don't forget to do that one as well.
True, I will do it later as it is easier and quicker to get to
Post by NachaLuva » Fri Jun 07, 2013 2:22 pm
The rear diff plugs are fun! Most people get away with using a 1/2" drive but mine were stuck solid. I ended up getting a 13mm square male socket for it...
thunder039
Post by thunder039 » Fri Jun 07, 2013 6:51 pm
it amazing how good the 4sp shifts once the oil is changed
2004 subaru forester -gone
1989 subaru brumby- sold!
2008 zook jimny -sold!
Post by Silverbullet » Fri Jun 07, 2013 7:21 pm
thunder039 wrote:it amazing how good the 4sp shifts once the oil is changed
Really? Put g/box oil change on my to do list then...every 4sp I've ever driven has shifted like total crap and has made me hate them forever :?
Post by steptoe » Fri Jun 07, 2013 7:47 pm
Sam , be curious to know if your dad recalls changing SB's gearoil - might be yer problem ?
Cliff R
Post by Cliff R » Sat Jun 08, 2013 1:05 pm
Picked up some Nulon 80W-90 gearbox/diff oil and some G70 for good measure.
Don't know when I will get time to do the jobs as it is raining/other stuff on/car being used over the weekend etc but should be all OK
thunder039
Post by thunder039 » Mon Jun 10, 2013 1:13 pm
yep really the 4sp dont have a good reputation but once the slop is fixed i like the 4sp
