Rebuilding a Hitachi
Posted: Sat Mar 16, 2013 8:49 pm
Some of you might know I've been debating about swapping the engine out of my Brumby for my other engine to get a few more beans. This is now definitely happening but I wanted to first give some attention to the carby to see if I can't fix a little issue it had and get some better economy.
Carbie kit arrived yesterday (Thanks again FROG!) and today I should have been welding on the wagon but my dremel decided to crap out this morning which ended that idea. So I couldn't waste a whole day, decided to have at the cabie since I had a full can of carbie cleaner lying around. And this is the write up of what I did today. I didn't go as far into it as what some might call a complete rebuild, I just took it apart, cleaned everything and put it back with some new parts. Somebody has done this before since there were some bits missing. I've rebuild one of these before and it's very straight forward...but it didn't end well for other reasons not gone into here
My carbie is a manual choke and very simple, some are auto choke which I have no experience with and can be a bit more complicated on top.
So firstly you take the carbie off the inlet manifold and set up a clean space on your bench. Get yourself setup with something comfortable to sit on, something to listen to and your carbie, rebuild kit, tools within reach and the destruction manual. I also had an ice cube tray to put all my crucial tiny jets and air bleeds in individually with labels. Also a good idea to give the carb a rough clean down to get rid of the large chunks of gunk that builds up (why is this stuff always brown?
) I didn't do this and kinda regret it.
Start dis-assembly by removing the solenoid at the front (big hex thing) and the choke cable bracket at the back (2 screws) Remove the two return springs on the choke and throttle linkages and undo the screw that the accelerator pump pivots on. Remove the pivot arm from the accelerator linkage. Then remove the choke linkage (split pin, washer, spring) from the choke shaft.
Now you can undo the remaining 3 or 4 screws holding the upper plate to the float bowl/lower assembly and remove it. Be careful here as you are now into loose spring and ball territory. DO NOT turn the float bowl upside down whatever you do, there is a spring, ball and weighted pin sitting loosely inside. If these fall out you will never know where they came from. Here I removed the float and fuel needle from the upper plate and set them all aside. You can also remove the secondary throttle diaphragm (big can at the back) if you have it, there is a gasket between it and the carbie itself.
Fuel needle and float removed:
Now this is where things can get a little complicated. On the lower part you will see the tops of all the jets and plugs screwed in. Each of these does a very specific task and they are all different. It is very important that these go back where they came from when you're done. Draw a diagram of the top and the location of each jet/plug and at which point they are tightened up (flat head screws pointing to 1 o clock, 6 o clock etc)
You need the book or assembly sheet here to label each jet as you take it out and put it in its own separate container. Now you can remove the spring and ball from the accelerator pump bore (label them!) and the weighted pin from the D shaped hole next to the pump bore. Make sure you know which hole it came from.
Individually labelled:
Now remove the two main jets accessed from the bottom of the carb below the float bowl. Two 12mm hex plugs hide the jets themselves. One is the primary main and the other is the secondary main, again don't get these mixed up and make sure they go back in the same place when re-assembling.
