				Dual range sedan lever
				Posted: Sun Jan 20, 2013 6:41 am
				by bensmith87
				Hi all,
I've put a dual range gearbox into a 1997 RX sedan from a 2.0 2000 forester. It's all working great, however I'm sick of popping the bonnet to get low range.
Does anyone know if I can get the entire console and lever out of a 2nd gen dual range outback and it will just bolt in, or if there are some nuisances that I need to consider?
				Posted: Sun Jan 20, 2013 7:46 am
				by Gannon
				Is your 97 RX a Liberty or an Impreza?
If its a Liberty, the Outback console will bolt straight in, if its an Impreza, use a Forester console
				Posted: Sun Jan 20, 2013 8:00 am
				by bensmith87
				It's a liberty, that's good news cheers.
One more thing, there is a spare plug comming out of the loom next to the neutral and reverse switch plugs, is this for the low range switch?
It does not make any lights come on in the dash when I short it, maybe I also need a new cluster...
				Posted: Sun Jan 20, 2013 5:32 pm
				by d_generate
				Why not just cut a slot in the console you have now? It's what I did here.
				Posted: Mon Jan 21, 2013 12:54 pm
				by AlpineRaven
				Gannon wrote:Is your 97 RX a Liberty or an Impreza?
Hes correct.. Gen 1 & 2 liberty has the same cable but Gen 2 has different colour lever but basically both same.
				Posted: Tue Jan 22, 2013 6:32 am
				by bensmith87
				Great, I'll head to a wrecker on the weekend.
				Posted: Tue Jan 22, 2013 7:02 am
				maybe you don't short the wire but power it ? Subaru used to send power through gearbox switches in MY and L series - doubt they'd change ...
				Posted: Mon Jan 28, 2013 3:01 pm
				by bensmith87
				If anyones interested, I just needed to put a new bulb in the dash and the low range light works.
				Posted: Sat Feb 02, 2013 2:19 pm
				by bensmith87
				I finally got to a wreckers, $30 got me the cable and lever but he didn't have the right bit of plastic so I've cut it until I can find one.
Pictures if anyone cares.
I cut a hole in the rubber boot thing.
I think this is how the cable is ment to run...
Lost the awesome coin holders
Success!
				Posted: Sun Feb 10, 2013 8:11 am
				by AlpineRaven
G'day,
The cable position is incorrect, it should be on the right side of the shifter, if you leave it like that you'll notice shifting doesnt feel right as its rubbing.
