Page 1 of 2
WRX Rear LSD
Posted: Tue Oct 30, 2012 8:08 pm
by hydrowill
Does anyone know weather all MY98 WRXs came out with a LSD.
Did the auto?
Posted: Wed Oct 31, 2012 5:36 pm
I'm sure they all did. Why wouldn't they come out with one??
You can get any R160 LSD and swap them into the subaru housing you've got - keeping your diff ratio.
There's a thread on here that tells you how to do it. Pretty straight forward!
Posted: Thu Nov 01, 2012 10:02 am
by RSR 555
Yep.. All Aussie delivered GC8 (Turboed Impreza code) came out with Viscous LSD. The early ones came with male shafts sticking out, whilst the later models required male spline shafts on the inner CV Joint.
This applies to auto and manuals but you have to remember they both have different ratios. What are you tying to do?
Posted: Thu Nov 01, 2012 3:35 pm
by hydrowill
Hoping to pick up an LSD for the outback. And swap the ratios as I have a spare 4:11 lying around.
Posted: Thu Nov 01, 2012 5:28 pm
by hydrowill
Could you link me to the thread bennie?
Although I'm sure it should be pretty straight forward when I have both of them sitting in front of me.
Posted: Fri Nov 02, 2012 9:54 am
by RSR 555
You can buy a 4.11 LSD out of a imported WRX or do the swap like you're thinking, either way you'll need the 2 cv shafts for it, as they will be different to yours.
Posted: Fri Nov 02, 2012 12:33 pm
by Venom
I thought the early ones came with the female diff and male inner CVs.
Posted: Fri Nov 02, 2012 8:52 pm
by hydrowill
After doing some google imaging it does look like the gc8 diff has female holes to accept the c/v joints.
Posted: Fri Nov 02, 2012 11:03 pm
by RSR 555
I has both types from the import GC8 rally cars.
From what I've found over the years is that after late 1994 they went over to the male splines on the CV joint/shafts but either way, you're going to need new inner joits as the VLSD has an extra spline on one of the joints and the clip/groove is in a different place on the other joint.
I'd just saying, when buying the LSD diff (what ever ratio you buy) make sure you get the correct cv shafts to match the diff. Crownwheel and pinions can be swapped but the shafts cannot. If you are swapping the CW & P, I'd recommend you replace bearings and crush tube.
Posted: Sat Nov 03, 2012 8:03 am
by hydrowill
Thanks for the advice man. Will save a big headache. As for the bearings I will keep this in mind.
How many KMS do the Viscous diffs last usually?
Posted: Sat Nov 03, 2012 6:16 pm
by vincentvega
mines done around 300K and still works as it always has: pretty crap but better than not having one
Posted: Sat Nov 03, 2012 9:39 pm
by hydrowill
Ok now I'm really quite confused.
Pulled a diff out of a WRX at the wreckers.
It came out of a WRX so you would assume LSD
Both shafts spin in the same direction as you would assume for an LSD
Was some slip when holding one wheel and turning the other as you would assume for an LSD.
However when I opened the back of the diff, there was no viscous center
looks like a normal open diff.
Does definitely not behave like an open diff. What have I got :s
Not welded.
I have seen somewhere someone saying about an open style LSD but thought it was bull@#*$ . Any Ideas?
Posted: Sun Nov 04, 2012 1:28 pm
Got a photo for us to look at?? That'd be the best way to work this one out!
Posted: Sun Nov 04, 2012 1:30 pm
by hydrowill
Yeah I'll take one and put it up tonight. Really does just look like an open diff however. I'm stumped.
Posted: Sun Nov 04, 2012 2:29 pm
by TOONGA
It could be a torsen LSD. that would be a very lucky find.
Posted: Sun Nov 04, 2012 3:22 pm
by hydrowill
but wouldn't that still have an obvious center? This just looks like an open diff.
Posted: Sun Nov 04, 2012 3:38 pm
by TOONGA
we won't know what it is until pictures are posted
hydrowill wrote:but wouldn't that still have an obvious center? This just looks like an open diff.
Just keep working on that pic!
Posted: Sun Nov 04, 2012 4:05 pm
by TOONGA
read
this 3 pages of arguments on the same thing, a diff that's meant to be LSD but looks open.
He pulled it apart in the end and it had plates for the VC internally. o.O
anyone a NASIOC member that can see the pictures?
Posted: Sun Nov 04, 2012 4:11 pm
by RSR 555
Sounds like a 'Hydratrak' diff. They work good but are a PITA on the wet stuff.
As for kms from your LSD, it depends on how its looked after service wise.
