ej22 auto
chubby37
ej22 auto
Post by chubby37 » Thu Sep 27, 2012 11:20 pm
I lost my book and can't remember things...how much fluid does an ej22 auto hold.cheers...bill
thunder039
Post by thunder039 » Fri Sep 28, 2012 7:49 am
not 100% sure on the ej22 but my ej25 holds about 9liters maybe 9.5 but you cant drain it all in one go needs to be pumped out, with fresh stuff going in due to the torque converter
2004 subaru forester -gone
1989 subaru brumby- sold!
2008 zook jimny -sold!
Post by TOONGA » Fri Sep 28, 2012 9:21 am
Australian delivered 4EAT 8.3 ( 8.8 7.3) L (US Q, imp Q) for either the EJ20 or the EJ22, this is taken from the 92 liberty/legacy specifications of the 1992 FSM.
showthread.php?t=20093
chubby37
Post by chubby37 » Fri Sep 28, 2012 4:32 pm
Would over filling it cause loss of drive at times...I can drive it but after 10 minutes it starts to loose drive but if I stop,turn it off and let it settle down I get drive back.then the same thing in 10 minutes again.
Post by TOONGA » Fri Sep 28, 2012 5:37 pm
It shouldn't, from the sounds of it the bands are overheating causing the box to slip and lose drive.
what colour is the fluid and when was it last changed?
chubby37
Post by chubby37 » Fri Sep 28, 2012 9:06 pm
The fluid was darker red but its hot new stuff in it now
Post by TOONGA » Fri Sep 28, 2012 9:21 pm
have you ever adjusted the bands?
or has it ever had a major service, eg the filter kit done?
Toonga
chubby37
Post by chubby37 » Fri Sep 28, 2012 10:27 pm
No I have never adjusted the bands but was about to ask how....cheers for that...since I sufferd a little brain damage due to that opp I had I forget things I use to know really well.....I'll let you know how I go.
Post by TOONGA » Fri Sep 28, 2012 11:23 pm
The torque listed in the specifications is 9nm (this is for step 5)
the locknut torque is 24 - 28nm.
Toonga
chubby37
Post by chubby37 » Sat Sep 29, 2012 8:22 pm
Oh ok....will see how I go
chubby37
Post by chubby37 » Wed Oct 03, 2012 10:20 am
Seem to have had a win....thanks heaps.....will put it in for a service but at least its working again.
Post by TOONGA » Wed Oct 03, 2012 10:35 am
good to see it is working for you.
I just hope when it goes in for a service, they don't tell you it needs to be replaced or some other guff. :)
chubby37
Post by chubby37 » Wed Oct 03, 2012 1:59 pm
I adjusted the bands a couple of small amounts but still loss of drive when hot.
chubby37
Post by chubby37 » Wed Oct 03, 2012 2:07 pm
Could it do the same thing if its over tightened at all
Post by TOONGA » Wed Oct 03, 2012 2:27 pm
How much did you ajust the band?
if you followed the book then it should not be a problem.
I would think that the box may be on its way out.
sorry
chubby37
Post by chubby37 » Wed Oct 03, 2012 2:36 pm
About half a turn......Zita did hit...well backed over a traffic island in our street once and I have only just had a close look and it looks like its dented the pan...looks to be right were the pick up is.maybe I'm grabbing at straws.I'll fix that and if no change ill need another good auto..........some days I wish we still rode horses
Post by TOONGA » Wed Oct 03, 2012 3:03 pm
Vets cost nearly double an hour more than mechanics. :)
there is a box in the classifieds which would be a good buy.
vbclassified.php?do=ad&id=2107
chubby37
Post by chubby37 » Fri Oct 05, 2012 7:44 am
Fixed the car.it was a dirty filter inside the auto.$38 for a new filter kit
Post by TOONGA » Fri Oct 05, 2012 7:47 am
Whooooo hooooo breathe a sigh of relief.
$38 dollars in comparison to 700+ for a second hand box.
good to see it got sorted.
