gearbox interchangeability
Posted: Sat Sep 22, 2012 11:20 am
by mistergTrx
hi all, does anybody know the possibility of changing the auto gearbox from a 1994 liberty to a 1999 or other gen 2 auto box?
(has to be auto, due to my gf only having an auto license)
Posted: Sat Sep 22, 2012 11:54 am
by TOONGA
do you have the transmission product number? it will look something like this TZ102Z2CBA and is on the compliance plate on the cars body. as well it is written on the side of the transmission on a white sticker.
get that and it can be compared to the one on the 1999, if it is the same yes it can be changed, if it is different you may need to change the TCU that goes with the auto transsmission.
Posted: Sat Sep 22, 2012 1:01 pm
by mistergTrx
thanks toonga, so as long as i can match the transmission number, it can be swapped, i'll have a look tonight
Posted: Sat Sep 22, 2012 1:14 pm
by Gannon
Gen3 (1998 ) and later transmissions are different and require a loom change to work. They are identified by the external oil filter on the passenger side of the transmission.
Im guessing your car is a 1994 Gen2 and the gearbox you are asking about is from a 1999 Gen3?
Posted: Sat Sep 22, 2012 1:38 pm
by mistergTrx
Gannon wrote:Gen3 (1998 ) and later transmissions are different and require a loom change to work. They are identified by the external oil filter on the passenger side of the transmission.
i dont have any gearbox in mind atm, but the auto in the gen 2 is starting to die, and have been told by the gearbox shop in gladstone that its not repairable and havent had much luck finding a replacement
so i figure im better checking out what else i can put in there
Posted: Sat Sep 22, 2012 3:00 pm
by Silverbullet
Auto license?
Never heard of such a thing...
Posted: Sat Sep 22, 2012 6:49 pm
by mistergTrx
Silverbullet wrote:Auto license?
in queensland, we get stuck with either a manual or auto license
and only if you have a manual license then you can drive either type but with auto it means only auto
