4.444 x 1.592. Ring gear mod details?
Posted: Sun Jul 08, 2012 6:59 am
Alright, I'm building a transmission for my brat. Stuff I have:
EA82/L series:
23 spline axle stubs, 1.592:1 Low and case from a Part-time 4WD box
Drive/driven shafts, 1-5 gears, speedo gear from Full-time 4WD D/R Turbo box
EJ:
Center diff and housing from a '93 impreza
Front ring/pinion shaft from a 2004 forester XT (4.444 5MT)
And a Carbonetic clutch-type front LSD
First test fit, don't have bearings on the Carbonetic yet, so I'm using the PT4WD front diff for now:
![Image](http://i26.photobucket.com/albums/c108/Numbchux/Brat/IMG_20120706_000059.jpg)
These are all USDM parts. it'll be used with an adapter plate behind an EJ18.
OK. I've heard many times mention of machining a 4.111 or 4.444 ring gear/crown wheel for this application, and I always imagined it was an issue with the outer diameter of the gear. BUT, after test fitting, I find it's actually the thickness that's the issue.
3.90 on the left, 4.444 on the right:
![Image](http://i26.photobucket.com/albums/c108/Numbchux/Brat/IMG_20120705_205222.jpg)
That difference, at the outer edge of the teeth, measures to about 2mm
![Image](http://i26.photobucket.com/albums/c108/Numbchux/Brat/IMG_20120705_235452.jpg)
![Image](http://i26.photobucket.com/albums/c108/Numbchux/Brat/IMG_20120705_235508.jpg)
I'm looking for some more detailed information from those who have actually done this (pics?) before I show up at a machine shop.
EA82/L series:
EJ:
