Stroking an EJ?
2nd Hand Yank
Stroking an EJ?
Post by 2nd Hand Yank » Thu Mar 08, 2012 6:28 am
Is is possible?
I'm wondering how much they can have their stroke length increased.
"Matt" in Townsville claims to have stroked his EA81 and it was easy. :-D
I did the math and found an EJ22 would be 2.5L by changing the stroke from 75mm to 85 mm.
Likely this modification would affect compression ratios too without major piston mods...
I wouldn't mind a 2.5L EJ22 that needs 98 octane because of a 10.5/11-to-1 compression ratio. :twisted: (torque? *drool*)
I'm not serious about this yet.
I just thought it'd be an interesting discussion topic.
Post by steptoe » Thu Mar 08, 2012 7:53 am
so too would be an EA81 stroker..... interesting discussion topic
dobo
Post by dobo » Thu Mar 08, 2012 7:58 am
cosworth and tomei and a couple other places make them.
I think they are mainly for turbo 22's though.
maybe a stroked 22 with a raptor supercharger :mrgreen:
Post by TOONGA » Thu Mar 08, 2012 9:41 am
dobo wrote:Image
Very nice, Im sure with the right pistons you could make an N/A stroker with those parts.
I don't suppose theree was a price for that kit? I'm guessing around the 3 grand mark before shipping.
stewbaru
Post by stewbaru » Thu Mar 08, 2012 10:22 am
The cheaper way of doing it would be to source an ej25 short block and put the 2.2 heads and inlet manifold on as they all bolt up with a little work on the head gaskets as the coolant channels don't quite line up. Called a high compression frankenmotor, there's a lot about it on the american subaru forums. Apparently the 2.2 heads are quite restrictive but its a cheap power increase if you already have an ej22, as the wiring then plugs straight into the existing 2.2 harness.
Are you thinking about this for your l-series? wouldn't it be easier to do the ej25 conversion in the first place?
Post by Gannon » Thu Mar 08, 2012 4:07 pm
2nd Hand Yank wrote: I did the math and found an EJ22 would be 2.5L by changing the stroke from 75mm to 85 mm.
There is little point increasing the stroke that far when a factory 2.5 was made using less stroke and more bore
EJ20
Displacement: 1994 cc
Bore: 92.0 mm
Stroke: 75.0 mm
EJ22
Displacement: 2212 cc
Bore: 96.9 mm
Stroke: 75.0 mm
EJ25
Displacement: 2457 cc
Bore: 99.5 mm
Stroke: 79.0 mm
FB20
Displacement: 1995 cc
Bore: 84 mm
Stroke: 90 mm
FB25
Displacement: 2498 cc
Bore: 94 mm
Stroke: 90 mm
Interestingly, a member of RSLC bored and stroked an EJ22 and came up with 2.7L, but his results were never claimed.
If you really wanted a project, get a reasonably new EJ25 with AVCS and plastic intake manifold, bore and stroke it as much as you can.
Post by Alex » Thu Mar 08, 2012 4:23 pm
is it really worth stroking a n/a motor when a turbo would be cheaper, more reliable and more powerful? Heck, a gen3 H6 would probably be cheaper...
ive heard of many ej20 turbos stroked out to 2.2/2.3l.
taza
Post by taza » Thu Mar 08, 2012 10:49 pm
Alex wrote:is it really worth stroking a n/a motor when a turbo would be cheaper, more reliable and more powerful? Heck, a gen3 H6 would probably be cheaper...
You can get an EZ30R for $2000 with 29,000km right now!
2nd Hand Yank
Post by 2nd Hand Yank » Sat Mar 10, 2012 5:25 pm
taza wrote:You can get an EZ30R for $2000 with 29,000km right now!
Would that fit in an L Series?
taza
Post by taza » Sat Mar 10, 2012 7:34 pm
2nd Hand Yank wrote:Would that fit in an L Series?
With alot of work, plus you would need a whole new drive train, gearbox, diff, etc..
Its is possible though.
niterida
Post by niterida » Sat Mar 10, 2012 11:13 pm
And you would have to grovel to me to sell you the aforementioned EZ30.................
Post by El_Freddo » Sun Mar 11, 2012 12:04 pm
taza wrote:With alot of work, plus you would need a whole new drive train, gearbox, diff, etc..
Dunno about a whole new drive train - Venom's running an EA gearbox behind his H6, it's the EA AWD with locking centre diff cased with EJ dual range casings.
The issue would be the radiator as the L series engine bay isn't as long as that of the liberty or forester...
