97 Forester Fuel issues
- Richie-Rich
Hi All,
Seems the hot weather has taken its toll on my old girl.
Went up to wedge via the H/way on Sat and got 300k's to my 45L tank. Thats down about 100 from normal city driving and about 150 from normal H-way. Was also down on power slightly.
Not sure where to start with this one, any help would be appreciated.
Rich
Rich
- thunder039
the headwind along the new stretch of road before wedge is a killer.
my 2001 outback also used about 10-20% extra fuel on my recent trip to wedge.
Its been 44+ up here and my Foresters not so keen on the heat.
I found when coming up from Geraldton my fuel economy was crap but I was going against the wind with a full load and aircon flat out in 45 degree heat
Got 200km from the first half compared to my usual 300-350km from it.
The otherday my Aircon just decided it didn't want to work at all and the car outside temp guard was saying 49!!! But after some drivng it just started working
How was your trip back? Or what about today, is all the power there?
The heat and especially hot wind will make a difference for sure.
- Richie-Rich
Thanks for the replies.
Car was not really loaded. Only change would be finally got a spare wheel that is the correct size and this now has to live on the roof. it is 190k from my dor to wedge, all 100k, and i was less than half a tank remaining. Power seems to have slightly returned.. not that there is much. Tyre pressures are about right for the size tyre.
Taza I have never seen that sort of economy from my foz.
Things I am speculating about;
02 Sensor replacement
Injectors needing a clean
- Richie-Rich
Try some Subaru upper engine cleaner, Might help slightly
Thats an extra 100,000km than mine on the engine.
Has your O2 sensor ever been replaced? That could be worth doing, you can get a bosch one for around $180 or OEM for around $450-500.
The worst I got was 25l per 100km. Only got 250km from a whole tank, this was however an extra 1tonne added to the car and trailer included going against 70km/hr head winds
Also had 1metre high of stuff on the roof
- thunder039
i have also never got that sort of economy out of mine usually 260-300 max to half and bout 500-600 out of a tank.
the spare tire on the roof will impact your fuel economy due to catching so much wind
2004 subaru forester -gone
1999 subaru forester- no more
1989 subaru brumby- sold!
2008 zook jimny -sold!
- Richie-Rich
- Richie-Rich
- thunder039
- Richie-Rich
Thats the tyres I run, the spare does fit in the wheel well. Just knock the panels out slightly with a rubber malletRichie-Rich wrote:Got Geo AT/R 215/70. full 2 inch lift. So I understand I'll take a hit, but 300k to a tank is nuts junior!!
Before I had my engine issues I would quite easily get 500km+ every tank no matter if it was the highway, around town or beach driving. Now its around 300-450 but I need to get some semi-major mechanical work done. Before the issues too I almost got 800km once on the highway while doing 100km/hr
400, that really does seem quite low. Maybe try some SUEC, a new O2 sensor (usual life of around 150-250k km). What about spark plugs, leads, oil change? Hows all that?
- Richie-Rich
Richie-Rich wrote:I'll chase up the 02 sensor and the engine cleaner.
Oil is only been in for about 5k, spark plug leads etc not to sure on, but i'll check.
Out if interest Taza, what type of pressures you running on the road with the Geo's?
Also thanks for the mallet tip!
You can get the engine cleaner from a Subaru Dealer, should only cost $15 or about that.
I run 31-32psi in my tyres all round. I did have 34 but it wore in the middle abit too much and if I run 29-30 it wears on the outside. 32 is a good inbetween
I did the mallet idea in the engine bay too so I could move the battery to the otherside. Now fitting a supercharger to where the battery originally was for abit more power
It could be worth doing the leads and spark plugs if they haven't been done in a while.
Taza
- thunder039
Yeah, I got 640 with Geraldton driving. So kind city and at that point I went around a corner and she spluttered abit. I worked that out to be something like 7L per 100km around town. or 7.5. Something like that. Plus that was with my bigger tyres, lift kit installed and roof racks onthunder039 wrote:wow 800ks! thats nuts. my best was 630 with fuel light just coming on
Thats a cool roof top tent you have on the foz!
Now i seem to get worse economy on the highway than around town. I get about 400km to the tank on the highway now
- thunder039
400km on the highway is pretty crap :P
whats this super charger your putting on?
I want a roof mounted tent but since im moving to the city it wouldn't be worth it. Im putting an SC14 toyota Supercharger on and will run about 4.5psi boost. Should give me around 35% more power, so silimar if not slightly more than the 2.5 in the next gen foz. Plus it will give me heaps of torque which is needed as the 2.0l currently just runs out of puffthunder039 wrote:thanks i love the tent!
My engine has to come out this year sometime though as my massive power and economy loss is due to her burning over 1litre of oil ever 1000km. But once thats sorted and with the SC she should be great
