EJ25 blowing smoke...
Thalass
Post by Thalass » Thu Oct 20, 2011 4:50 pm
Hey guys. The old Outback is playing silly buggers again. When the engine is cold it's blowing a bit of smoke.
I feared that water was getting where it shouldn't but the water levels are unchanged. However she is using oil - not very fast though. The last bloody thing i need right now, but there you go. There aren't any oil stains on the driveway, and the underside looks clean enough so i'm a bit scared it's a gasket or something.
Any thoughts? Thanks.
Post by TOONGA » Thu Oct 20, 2011 5:50 pm
what colour is the smoke? if it has a blue tinge it is oil, white is coolant and grey is buy a new motor.
A small amount of steam is normal as the engine warms up and condensation in the exhaust is turned to steam.
How many KMs has the motor done? it could be oil getting past the rings if the engine has high KMs.
Is the PCV working properly?
Thalass
Post by Thalass » Fri Oct 21, 2011 9:21 pm
Well as far as i know the car has only had one engine, which makes it 240,000km old. It's had it's second 100k service recently (a bit late :roll: )
As for the PCV. We changed a PCV on the intake manifold for the 100k, but i don't know about any others.
Post by RSR 555 » Mon Oct 24, 2011 5:09 pm
Yep.. I replaced it at the 100,000km service but I'm thinking it's been a while since I've seen the car Ben, so best to drop over next time I'm home (just over 3 weeks)
Thalass
Post by Thalass » Tue Oct 25, 2011 5:40 pm
Right-o thanks, Paul. I'll see when i can set it up - I'm on course around that time so it'd have to be on the weekend if that's ok with you.
It's definitely blue, and stops once the engine warms up (or, at least, it reduces to the point where i can't see it billowing behind the car while i drive.). Damn thing.
revmax
Post by revmax » Tue Oct 25, 2011 6:17 pm
Just curious is it a DOHC @ 160-180K or 320-360K
Post by RSR 555 » Thu Oct 27, 2011 4:01 pm
No probs Ben.. just give me a call
revmax.. nah, it's a Gen3 Outback with the EJ25 SOHC engine. I'm guessing that the valve stem seals are due.
Post by El_Freddo » Mon Oct 31, 2011 12:05 am
RSR 555 wrote:I'm guessing that the valve stem seals are due.
My thoughts too Paul. Parts shouldn't cost much, but labour could be a bitch - its a bloody fiddly job!
Post by RSR 555 » Mon Oct 31, 2011 4:26 pm
El_Freddo wrote:My thoughts too Paul. Parts shouldn't cost much, but labour could be a bitch - its a bloody fiddly job!
Yeah.. and guess who'll get to do that :(
