EA82T Spider PCV insufficient?
Posted: Sat Sep 10, 2011 9:44 am
A thought occurred to me as I worked on my spider set up, that the partial flattening out of the PCV hose as it clears the other breather elbow at the turbo end of th air duct pipe, is that it gets a bit squashed and may not breathe as efficient as planned by the engineers.
A 100km drive up and down the highway the other day , parked the beast, and for the first time I see an oil leak evident on the floor. Dropping directly from the gearbox drain plug (lowest point?)
I am yet to smell gearbox oil to see if it is engine or the pungent 80W90 stuff.
The 80mm dia spread on the floor had no smell - so likely engine oil, likely rear main oil seal that has 600km on it
Only did it in the last 100km, not the great mix of driving for previous 500km
I am thinking I need to rig up a catch can, breather and hose config to reduce the possibility of the factory PCV system not coping.
There is very little chance of getting factory breather hose to PCV valve to full flow capacity in its tight fit
Anyone else considered this with the spiders?
edit >> I should add that the PCV valve is nice and clean, works etc
