Help needed subaru liberty dual range problem
wicked101
Post by wicked101 » Tue Jul 19, 2011 8:00 pm
hi
im new to this forums and ive been having a problem with my subaru
deatils of my car:
subaru liberty ej22 (2.2ltr) 4WD/AWD rallye
i just got a new clutch kit (oem replacement) on my car including flywheel machining as the old one was slipping so i took it to the mechanics to get it replaced now the lo range light is always on even if the gear stick (for the dual range) is down where its supposed to be high when i pull the lever up it the car doesnt go at all does this need ajdusting or is somthing wrong
the problem is like it wont go into normal/high range but i really dont know wich one its in all though the car feels more jumpy when i release the clutch but maybe that could be because the clutch is new and is gripping better but there is somthing defantly wrong with that
some help would be greatly appriecated
thnx
Post by TOONGA » Tue Jul 19, 2011 10:03 pm
take it back to the mechanic and explain the problems, even if you have to get him in the car and demonstrate them for him.
H-top
Post by H-top » Tue Jul 19, 2011 10:07 pm
Not put back together properly.
H-Top
rolling in
Post by El_Freddo » Wed Jul 20, 2011 9:37 am
Sounds like the low range cable is swinging in the air while still in low range.
Top speed in 5th of about 90km/h or there abouts?
Post by guyph_01 » Wed Jul 20, 2011 10:44 am
Ypur mechanic must have forgot to do something. Maybe what elfreddo said.
Post by El_Freddo » Wed Jul 20, 2011 10:46 am
guyph_01 wrote:Maybe what elfreddo said.
No maybe about it Guyph :rolleyes:
Ah... I need some sleep!
wicked101
Post by wicked101 » Wed Jul 20, 2011 3:28 pm
thnx for all the replys taking back to mechanic most likly for the cable to be ajdusted thnx for all the help
greywarden
Post by greywarden » Thu Oct 06, 2011 6:01 pm
wicked101 wrote:hi
thnx
ever since my car became a victim of flood leaving my subaru half submerge in the water my car already feels jumpy whenever i am shifting gears and releasing the clutch. until now i am just ignoring it.lol am i in trouble? looks like i need to visit my mechanic again. i just got replacement subaru parts from this site.
d_generate
Post by d_generate » Thu Oct 06, 2011 8:37 pm
I hope you flushed the box & diff before putting new oil in them.......you did put new oil in them I hope!!!
Post by El_Freddo » Sat Oct 08, 2011 6:17 pm
It could be that the spigot bearing is seizing up or not operating smoothly as a bearing should.
