diff oils...
skrewd
diff oils...
Post by skrewd » Wed Jun 01, 2011 8:31 am
i would like to pick your brains and ask what the best oil is to run in ya diff, i would like to know the thickest you can use without causing dramas....thanks
Post by sven '2' » Wed Jun 01, 2011 9:32 am
Just curious, why are you keen to use a low viscosity diff oil? Have always used the std oil, and with all that things that have broken / blown up, have yet to a diff let go.
Are you trying quieten a worn diff?
skrewd
Post by skrewd » Wed Jun 01, 2011 6:12 pm
sven '2' wrote:Just curious, why are you keen to use a low viscosity diff oil? Have always used the std oil, and with all that things that have broken / blown up, have yet to a diff let go.
i changed the oil in it 2 weeks ago (oil in it was not looking good when it come out) and a whine appeared went back to work and changed it again but the whine is still there. maybe i just never noticed it before i changed oil the first time...:confused:
littlewhiteute
Post by littlewhiteute » Wed Jun 01, 2011 7:16 pm
Penrite LSD 85W140.
Have changed many diff oils to this with great results.
Gary ;)
Post by Alex » Wed Jun 01, 2011 7:23 pm
littlewhiteute wrote:Penrite LSD 85W140.
+1
Post by El_Freddo » Thu Jun 02, 2011 2:18 am
I'm running an LSD gear oil in both the rear diff and the gearbox.
The gearbox seems to change smoother since doing this. Reason for last oil change was a "sunken" Ruby Scoo :(
skrewd
Post by skrewd » Fri Jun 03, 2011 8:16 am
thanks guys i might give the 80w 140 a go and see if that makes a difference
