Alex wrote:
are they clicky? no point changing the boots if the actual joint is stuffed.
Yeah go a new set - I've just been playing around with my CVs to save a few dollars only to have them click worse than before (did the swap side trick) and split a boot again anyway. So I've got another set of old ones I had lying around installed that also click, just not as bad...
I'm working out wether to get a new set or not - got a few things on the go but a new set would solve my problems for a while...
Alex wrote:personally id go for new shafts, then you know theyre good and will probably last the life of the car.
Life of the car... unless you've got an EJ
A few hills, couple of corners a bit of throttle or more - you get the idea
