EJ22 engine manual same as auto?
- MidcoastScooby
Hi, haven't been on this forum since my son rolled the L-Series last year. I now have a new project.
Can the EJ22 motor be swapped from an auto car to a manual car? All I want to do is swap motors over, anything I need to change or check on? Is it easier to drop the motor or lift it out?
Thanks in advance.
Thanks in advance.
You can use a EJ22 mbehind either manual or auto.. the engine are the same, you'll just need to swap over the obvious things like flywheel/clutch but everything else is the same
Engine will need to be lifted out as the crossmember is in the way of dropping it out the bottom
People have different opinion about taking out engines. For me due equipment I have I find easier to pull engine out with gearbox attached from top while cross member still attached to the chassis with Radiator removed first.
- MidcoastScooby
- FROG
I think the starter motors are different from auto and manual ..... I think ....
Depth of throwout ???
- FROG
Ah yep , alarm bells were ringing
- vincentvega
starter bolts to the gearbox so that really doesnt matter.
one thing that is different is there is a guide on the timing belt in the manuals to stop the timing belt skipping a tooth. its not fitted on the autos. This wont be a showstopper though. plenty of people have converted to manual without worrying about this.
