DCCD centre for Gen4 Outback dual range
Barry1956
Post by Barry1956 » Wed Feb 02, 2011 9:50 pm
At some point I'm going to pull down my transmission to fit scorpion low range gears.
Does anyone know if the WRX DCCD would fit in the case as well, and if so, how difficult it would be to wire up?
DCCD + low range = good climbing in the High Country of Vic! :twisted:
H-top
Post by H-top » Wed Feb 02, 2011 10:15 pm
It's 2 wires to the controller. But I reccomend
getting an aftermarket item as they are
infinately easier and more advanced that the
factory one.
I've got a DCCDpro for mine. Canadian made.
5 wires. I'll never look back.
And yes, it will fix any 5 speed :)
H-Top
rolling in
niterida
Post by niterida » Wed Feb 02, 2011 10:25 pm
I don't really know anything about dual range gearboxes but I would imagine that the dual range part of it is in the rear housing of the gearbox which is where the dccd goes ??
So what I am saying is can you have both ?
legacytt
Dccd
Post by legacytt » Thu Feb 03, 2011 10:13 am
The dual range is in the front of the box so seperate to the rear housing. You will need the complete rear housing off a DCCD box and I am not sure if this is a direct bolt on to the newer boxes. It will fit Gen 1 Liberty dual range as that is what I have in my H6. Makes a great box for both on and off road
niterida
Post by niterida » Thu Feb 03, 2011 11:15 am
legacytt wrote:The dual range is in the front of the box so seperate to the rear housing. You will need the complete rear housing off a DCCD box and I am not sure if this is a direct bolt on to the newer boxes. It will fit Gen 1 Liberty dual range as that is what I have in my H6. Makes a great box for both on and off road
You don't need the dccd housing at all. The dccd centre will go into a non-dccd housing - it just needs a hole drilled in the top of the housing to allow the controller wires to feed through. There is one other thing you have to modify internally but I'm not sure what it is but it is not hard (this is from what the builder of my dccd into a non-dccd box said).
They will fit all 5 speed EJ boxes.
Barry1956
Post by Barry1956 » Thu Feb 03, 2011 3:25 pm
H-top wrote:It's 2 wires to the controller. But I reccomend
factory one.
What was that worth? Did you have to import direct, or do they have a local supplier?
legacytt
Post by legacytt » Fri Feb 04, 2011 6:37 am
niterida wrote:You don't need the dccd housing at all. The dccd centre will go into a non-dccd housing - it just needs a hole drilled in the top of the housing to allow the controller wires to feed through. There is one other thing you have to modify internally but I'm not sure what it is but it is not hard (this is from what the builder of my dccd into a non-dccd box said).
So have you fitted DCCD to the later rear housing which does not have the removeable plate on the top like the early ones? I was under the impression, but could be wrong, that these newer style rear housings won't work with the earlier DCCD's due to different internal design.
ScubyRoo
Post by ScubyRoo » Fri Feb 04, 2011 8:04 am
Barry1956 wrote:What was that worth? Did you have to import direct, or do they have a local supplier?
http://dccdpro.com/zcart/index.php?main ... oducts_all
I couldn't find mention of an Australian supplier, but then I didn't look particularly hard...
Barry1956
Post by Barry1956 » Fri Feb 04, 2011 8:24 pm
I guess my first question should be ... where can I source a DCCD Centre Diff! :rolleyes:
H-top
Post by H-top » Fri Feb 04, 2011 10:20 pm
ScubyRoo;
I run this on my V2 STI RA Lib and they ship direct to oz.
made in canada.
magic bit of kit.
H-Top
rolling in
Post by El_Freddo » Sat Feb 05, 2011 12:50 am
ScubyRoo wrote:http://dccdpro.com/zcart/index.php?main ... oducts_all
You don't really need one these days - either have them send it direct to you and if they don't do this set up an account with a pack and send "virtual mailbox" company - Venom has details about this as he's got one sorted for when he purchased all the gear for his H6 that was needed ;)
