I'm buying
an Impreza sports wagon and it needs a radiator.
My libbo still has the stock NA radiator and want
to swap it into the impreza.
Is this a direct swap and can I use a GC8
eBay alloy radiator to swap it with?
Are they reliable?
Anyone used them on the forum?
eBay GC8 alloy radiator?
- bobbyjimmy
I've got one in my Gen III Outback, bolted up perfect, fans bolted on in the right places etc.
BUT, because the radiator is now around 3 times as thick, I had to change the A/C fan to a slim line one as it fouled on the timing belt cover, and the main fan is maybe 5mm from the A/C idler pulley bracket and I *might* change it for a slim line one too.
I also didn't like the crap plastic drain plug on the side, so swapped it for a brass tap type one, and I also got a mate to weld the top overflow tube joiner (attaches to the filler neck) as mine just didn't look right - all good now and does keep constant temps, even in 40c days lugging up hills etc.
- bobbyjimmy
