I was wondering which one of the following pumps would be suitable for my Brumby EA81
Hylton:twisted:
http://cgi.ebay.com.au/ELECTRONIC-FUEL- ... 5889ead324
SOLID STATE FEDTRO ELECTRONIC FUEL PUMP FED-40104
Suitable for 12 volt only.
Supplied complete with metal fuel filter and 1 brass fitting at no extra charge.
FED-40104 – Pressure range 2.0-3.5 PSI – Max Flow 28 GPH
FED-40105 – Pressure range 3.0-4.5 PSI – Max Flow 30 GPH
FED-40106 – Pressure range 4.5-6.0 PSI – Max Flow 34 GPH
Solid state reliability
Eliminates vapour lock
Built-in pressure relief
Lightweight and compact
Easy to install
Compatible with all fuels
Self priming
Vibration resistant
Two wire design
Low cost
Faster low temperature starting
Easy to follow instruction sheet
Features and Benefits:
Universal electronic fuel pump, designed to replace hundreds of mechanical pump models.
Fits all carburetor equipped cars, vans and light trucks.
Easy to install: Two bolt installation plus the small size makes installation easy. For best results, mount the pump close to the fluid or fuel tank and below the liquid level.
Compatible with all fuels: No rubber diaphragms or valves to swell or deteriorate in alcohol blended fuels. Compatible with leaded and unleaded petrol, diesel fuel, blended alcohol fuels and fuel additives.
Eliminates vapour lock: When properly installed in most vehicles, a constant smooth, dependable supply of fuel under pressure is assured in the hottest weather or high altitudes.
Light weight – compact: Less than 3 inches (7.62 cm) in any direction – only 17 ounces (480 gr). A giant in output for its size.
Self priming: The pump is self priming to 12 inches (30.48 cm) fuel lift. No extended cranking in order to restart engine after running out of fuel.
Lower power requirement: Standard 12 volt models require approximately one amp at maximum delivery.
Built-in pressure relief: No flooding assures restarts on the hottest days.
Solid state reliability: Proven on thousands of various applications. No electrical contacts.
No bearing or diaphragms to wear out or fatigue. Lasts four or five times longer than many other electric pumps.
Two-wire design: Electrically isolated case. Eliminates possibility of corroded ground connection.
Corrosion resistant: The all steel case is plated for corrosion resistance.
Supplied with 2 brass fittings and fuel filter.
Comprehensive easy to follow installation instruction sheet.
