92/3 Lib dual range owner wanted
d_generate
Post by d_generate » Sun Sep 12, 2010 6:46 pm
Hey, just need a small favour, I'd like to know what speed you are doing at 4,000rpm in 2nd gear high & low and 4th gear hi/lo, just so I get an indication of what to expect from the d/r box when I fit it.
I'll be getting a 4.44 cw & pinion and a new STI front 1.5 - 2 way LSD & rear 4.44 viscous fitted so it'll be a bit better geared but a rough idea what difference to expect would be helpful. Ta :)
I'm not after a rock crawler, just something a bit better than the stock WRX 4.1 set up it has now.
Jeff
Post by Jeff » Sun Sep 12, 2010 8:48 pm
I hope you are getting an STI helical front LSD. I am running 4.44 front diff with a 1.5/2 way clutch pack LSD and hate it. It was set up as a 2 way and the car was almost undriveable so i had it changed to 1.5 way and backed off a little and it made some difference but the car drives like a pig around town and parking. I can't wait to find a helical or torsen from an STi to replace it with
Post by AlpineRaven » Sun Sep 12, 2010 9:12 pm
I'll get back to you tomorrow.
d_generate
Post by d_generate » Sun Sep 12, 2010 9:54 pm
I've got no idea what it is apart from being a genuine STi item, a mate imported it from Japanparts a couple of years ago and it's been sitting in it's box ever since, I know it's worth about $2,300 or more once freight & customs are paid but that's all I know....I'll take it to Steve at MMS this week so he can tell me what it is & the best way to set it up & tell me if it's helical or clutch but thanks for the warning though it's not usually my daily so not overly worried.
Thanks a lot AP, really appreciated.
Edit, looks like clutch pack, here's the repair kit parts.
LSD(1005G-019-083). Comes with Friction plate (1.70)x 6, Friction plate (1.80)x 6, Friction disc (1.70)x 4, Friction disc (1.80)x 4, Spring plate (1.70)x 2.
Post by AlpineRaven » Mon Sep 13, 2010 8:44 am
Based on Gen 2 3.7 D/R with 1.59:1 low
- high range in 2nd gear at 4000rpm is 60kmh.
- low range in 2nd gear at 4000rpm is approx 37-38kmh
Based on Gen 2 3.7 D/R with 1.19:1 low
- high range in 2nd at 4000rpm is 60kmh
- low range in 2nd at 4000rpm is 50kmh
Based on '94 Gen 1 3.9 D/R with 1.19 low
- high range in 2nd at 4000rpm 56kph approx
- low range in 2nd at 4000rpm 47kmh
d_generate
Post by d_generate » Mon Sep 13, 2010 3:05 pm
Thanks for that, so it looks like low is about a 20% drop in the 3.9 box which is what I have, I guess the 4.44 cw & rear diff change over should help a little with the 26" 205/60/16's to make it reasonable in the sand.
T'subaru
Post by T'subaru » Mon Sep 13, 2010 4:27 pm
Jeff wrote:I hope you are getting an STI helical front LSD. I am running 4.44 front diff with a 1.5/2 way clutch pack LSD and hate it. It was set up as a 2 way and the car was almost undriveable so i had it changed to 1.5 way and backed off a little and it made some difference but the car drives like a pig around town and parking. I can't wait to find a helical or torsen from an STi to replace it with
For your consideration guys. Helical lsd's
http://cgi.ebay.com/ebaymotors/OBX-JDM- ... ccessories
Cheers, Mark
Post by RSR 555 » Mon Sep 13, 2010 6:47 pm
T'subaru wrote:For your consideration guys. Helical lsd's
Cheers, Mark
Very noice.. please send me one for Xmass :mrgreen:
Post by AlpineRaven » Mon Sep 13, 2010 9:15 pm
d_generate wrote:Thanks for that, so it looks like low is about a 20% drop in the 3.9 box which is what I have, I guess the 4.44 cw & rear diff change over should help a little with the 26" 205/60/16's to make it reasonable in the sand.
Mmm yeah... I'm running 215/55 16s (which is 25.3") on my wagon at the moment..
205/60 16s is 25.7".
T'subaru
Post by T'subaru » Mon Sep 13, 2010 11:03 pm
RSR 555 wrote:Very noice.. please send me one for Xmass :mrgreen:
oopsie, i forgot to write "dont open until christmas" .....:P
d_generate
Post by d_generate » Mon Sep 13, 2010 11:47 pm
AlpineRaven wrote:Mmm yeah... I'm running 215/55 16s (which is 25.3") on my wagon at the moment..
Splitting hairs but close enough to 26" .... 25.685" to be exact ;)
Post by AlpineRaven » Tue Sep 14, 2010 1:46 pm
d_generate wrote:Splitting hairs but close enough to 26" .... 25.685" to be exact ;)
LOL That is right i was rounding up next digit.
d_generate
Post by d_generate » Tue Sep 14, 2010 3:30 pm
AlpineRaven wrote:LOL That is right i was rounding up next digit.
So was I, but to the nearest single digit ;)
