EA81 Piston Ring gap
Posted: Fri Jun 25, 2010 4:39 pm
EA81 Piston Ring gap with 40 thou or 1mm oversize pistons what gap does everyone think, gregories says 0.2 to 0.35 and limit 1.5mm. But what should i set it to? Anything above 0.2mm? It was bloody confusing the way it was written.
Side note i hate ACL!!!! i have 1 stuffed piston 1 stuffed set of rings (ripped the rings spacer thing out on the piston and the 2nd compression ring is in like 10 pieces) and 1 stuffed set of Crankshaft bearings all ACL!!! And all under 12 months old!!!!
Thanks
Matt
Thanks
Matt
