how to remove auto from gen 1 2wd???
benoz
Post by benoz » Sat Jun 05, 2010 4:02 pm
Hi everyone!
I need to remove and replace the auto trannie for my 2wd gen 1 liberty gx. can anyone give me a few pointers like: is it easiet to drop the trannie out the bottom or pull the engine as well, are there things that need to be removed in a set sequence?
A quick how to would be great
Ben
Post by AlpineRaven » Sat Jun 05, 2010 5:05 pm
There is a lot of treads in here..
since its fwd its lot easier than AWD models, its your choice with right equipment, if you have a crane you could pull the engine out altogether or drop the gearbox with a platform jack.
Timing for both - is pretty much close depends how mechanically minded you are.
For me... I can pull out a transmission from under the car in 45 mins with caution (for AWD models).
