Thanks Bennie,
Given JDM legacies seem somewhat available, if
/when I do another DR EJ5MT swap, I'd rather do a lower 1st also knowing I'd get a better 5th, one split between the Forester's .871 and the better overdrive .780 in USDM 3.90 cars. Low range swap aside, going as much plug-n-play as possible would be best. The less major fiddling the better for reliability and minimizing future needs to go heart-deep into a car to keep it driving. I'm in the camp of driving a car is better than wrenching on it (especially if its mine).
The reason I bring up the stock lower 1st is that I CAN tell the difference from the USDM 99 OB 1st and the AUDM 98 FOR 1st gear. i know numerically it's not much, 3.545 vs. 3.454, but factoring 1st and FD and low, here's some crawl ratio numbers...
hi range:
my AUDM 98 FOR. Hi 1st*FD*no lo=14.19594
03 USDM OBS Hi 1st*FD*no lo=13.8255
00-04 JDM legacy Hi 1st*FD*no lo=14.56995
lo range:
my AUDM 98 FOR. Lo 1st*FD*1.447 lo=20.54152518
03 USDM OBS (DR)Lo 1st*FD*1.59 lo=21.982545 (if modified with DR EJ 5MT)
00-04 JDM legacy Lo 1st*FD*1.19 lo=14.56995
00-04 JDM legacy Lo 1st*FD*1.59 lo=23.1662205
So If I cold put a dual range in my 3.90 OBS, keeping the 3.90FD but changed to a GL low, I'd have a slightly higher 1st gear than my 4.11 AUDM forester'ed legacy (which is fine with the EJ25) but i'd have a lower crawl ratio than my 4.11 AUDM forester 5MT.
The final lo range comparison (as some of you guys have done) is a GL low into a DR EJ 4.11FD gear box (here, JDM legacy) giving a 23.166:1 crawl (given the 4.11s, that's better than the GL DR 4x4s had AND that was behind an EA81) but this would be BEHIND AN EJ25!
This is the CO guy's plan for his 02 OBS.
And yeah, splitting it to put the GL low would be a must, and a front LSD would be sweet, but availability and co$t are serious factors there.
The oil feeder idea seems a good one, but if that mechanism fails inside the box, that's a $#!+ storm of potential problems!!
If
I do another one, it'll be b/c I sold my 95 legacy and got my wife's 03 OBS. I'd likely leave it a 3.90 for efficiency, but with a GL low (probably no need to modify the ring gear, it would be like the 93-94 Impreza then) it would rock on boat ramps (white water rafting rig... I do live in Moab after all
then maybe a 1" spacer and WRX or STi springs and a simple RSB upgrade, it would be a rally rocket AND a good road/highway car, AAnd plenty capable for regular and light duty needs.
I would surely be sad to not have the bad-assness of my Legacy now and again, BUT it is 18 years old and has 184K on it... None of that is going to get better with time
At any rate, given what we (in the States)
can get, it seems a DR legacy transmission (unless i/we can decode Outback guts and availability in dual range) would likely be the next offering, then swap the low. Again, if OBs are typically 3.90, then that could be good (again, depending on 1st and 5th) option.
El_Freddo wrote:I wouldn't worry about getting a lower first gear ratio - just drop the L series low range in!!!
While you've got the box split shove a front LSD in as well and get those extra oil feeders to the low range sorted too
You can get "better" 5th gear ratios from alldrivesuparoo.com (I think that's them). If need be ship them to me and I'll post them over if it's going to keep the cost down for you
