EA82 performance cams
Posted: Mon Mar 29, 2010 7:33 pm
by H-top
G'day all,
I've done cam swaps in LS1's of circa 270deg sized cams and it needs to be tuned following that to even idle correctly.
Would the same be true for a 4 plug EA82T? And would Stronger valve springs
be a must?
Further more, anyone be selling second hand ones
Sam
Posted: Mon Mar 29, 2010 9:58 pm
maybe just new from the mother country about 200 bucks for the set of inners and outers will do nicely
Posted: Tue Mar 30, 2010 4:43 pm
by spike
it will need tuning.
step toe was that you saying youve got some??
Posted: Tue Mar 30, 2010 9:08 pm
Yep, I got some eighteen months ago to fix a miss that developed due to the spring tension being about marshmallow strong and the yet to be blasted head shop fitted as the repaired and serviced them. Motor ran ever so sweet with the genuine babies fitted. No after market ready springs available through any channel tried. Waited the ten days from Japan.
Posted: Wed Mar 31, 2010 12:57 pm
by spike
ahh ok........................
yeah im going to have to get some for the race engine
Posted: Wed Mar 31, 2010 2:21 pm
by H-top
Roger, thanks guys
Posted: Wed Mar 31, 2010 7:31 pm
by Gannon
Being EFI, it probably wont need tuning. At most you might have to increase the idle a bit to compensate for the reduced air speed caused by the 'lumpy' cam.
Tuning is necessary with carbys because its the air pulses that suck the fuel in and any change to the speed and volume of air entering the cylinder needs to be compensated for
