Removing engine and transmission together?
- ScubyRoo
Hey guys
Well the work has started of the transfer between my liberties...
I'm wondering if it is possible to remove the engine and transmission together in one go?
I was wondering if I... remove the radiator, the transmission's crossmembers... then pull the whole thing up and out with the engine crane.
I was mainly worried about the length...
Anyone done it this way before? I figure it'll save me a bunch of time.
Owen.
Owen.
yes do it at one go, lot easier that way - LOT easier... (with right tools and knowledge) you could get the engine/box out in 45 mins) You need to remove the rad as well.
- d_generate
Yeah, I've done it from above (motor only) & below...........so much easier to leave everything in one piece, undo the X members & struts then just lift the front of the car up and drag it out/roll back under
Agreed. This is how I did my EJ conversion in Ruby Scoo, except I had the front of the car jacked right up instead of leaving the crossmember on the floor and jack the car... Didn't think of that!d_generate wrote:so much easier to leave everything in one piece, undo the X members & struts then just lift the front of the car up and drag it out/roll back under
- d_generate
Also helps to take the wheels off & you'll need to tie a piece of bar/wood across the top of the struts once everything is out to make maneuvering them easier, also keep a jack under the front of the motor as it may try to tip forward and squash your head like mine tried to when I undid the last bolt...........Missed by "that" much.
ive always lifted it thru the engine bay. All in one piece yes. Dropping it back in is just as easy as lifting it out.
Used a plastic bag (over the tailshaft end) and tape it up at the end of the tailshaft - works well.daza wrote:Drain it and plug it with a rag.
Daza
and make a big mess!
