Have i been had on eBay?
I bought a set of supposedly new TopGun ignition leads for my EJ25 and when they arrived, i opened the box to find Bosch leads.
http://cgi.ebay.com.au/subaru top gun spark plug leads,new
The seller claims that she bought them and never used them.
I know bosch are probably just as good, but i feel a little ripped, even though i only paid $40 for them
Opinions?
What would you do?
Opinions?
What would you do?
Are the leads exactly the same as the one in the picture on ebay?
I'd rather go for Bosch than other brands, currently I have blue NGK brand ones.
- TOONGA
in the strict terms of the auction you have a legal right to return the item as it is not as described but having said that bosch are way better than topgun leads (IMHO)
so you can file a dispute to get your money back or use the leads but leave feedback (positive but nasty:) ) stating that the leads while good were not the brand described and give them low star rating
- ScubyRoo
top gun = sh*t! I had these for a month before I bought the blue NGK that AP is talking about - thaey are the bee's knees, very happy with them.
The top guns actually came off 4 times on #1 cylinder, and twice on #3. Switched to NGK and will never use top gun ever again.
I'd say you got the better end of the deal, $40 bosche leads, thank you very much!ds
The Green Machine is up for sale . Lifted, bars, exhausts... View Gumtree ad
topgun>bosche>ngk.
bosch are worth more than topgun anyway.
the ngks are awesome tho. Id never use anything else after using them
i think your greater than/less than sign are round the wrong wayKeffa wrote:topgun>bosche>ngk.
should be
ngk>bosch>topgun
and i assumed NGK was worldwide. Supercheap even in eastern states should stock NGK plugs. and able to get leads in
So with the knowledge that Bosch are the better of the two, how do i tell if these are new or used?
- TOONGA
if the leads are in good condition they Should all be under 10000 ohm
on a multimeter if not they are cactus
how to do it select an ohms rating on the multimeter thats very Sensitive and connect one lead to each end of the lead and take a reading under 10000 ohms is good under 5000 ohms is very good
please correct me if it Im wrong but that what i remember (its been a long while since i tested a set)
Ok i tested them, readings are as follows
2.62kΩ, 2.83kΩ, 3.45kΩ & 3.42kΩ
All well below 5000Ω so well within their spec.
My concern was how did the Bosch leads get into the Topgun box? Did a parts dealer accidentally put a display item in the wrong box? Did somebody return the leads they just bought, but took their used leads back in the new box?
Who knows?
I'll put em in and if they work ok, i'll give neutral feedback
Who knows?
should be
ngk>bosch>topgun
I will let you all in on a little trade secret about ignition leads.....
Quality goes -> NGK, TopGun, Champion, Bosch.
Bosch is the only manufacture still to use carbon core leads on their 'standard' range.
Bosch leads make auto stores money they have the highest GP % of any on the market....
NGK, TopGun & Champion use a stainless steel spiral wire setup.
Bosch use the spiral wire in there 'performance' range.
TopGun & Champion are made in Australia by the same company.
NGK are Japanese made.
http://www.subiparts.com.au
0438 887 746
0438 887 746
