ea82 2nd jet not working?
Mr Top Hat
Post by Mr Top Hat » Tue Mar 02, 2010 12:18 am
hi everyone
i was looking at my carby today and noticed what appears to be a 2nd jet for the higher rev ranges didn't work
i had the engine running and i manually turned the throttle and saw the 1st one sprayed fuel in.
when i opened the throttle right up i noticed the 2nd valve opened but the jet didn't spray any fuel
is this normal or am i missing something?
thanks
TOP HAT
1990 L series wagon Ej22
i didn't realize this image was so large :-O
Post by steptoe » Tue Mar 02, 2010 9:09 am
Got a funny feeling that the fuel accelerator pump squirter do not operate on your secondary venturi, only primary. Secondary has a more gradual operation needing the air valve above throttle shaft butterfly to open first before fuel can be dragged out the secondary jet. I have used zip tie on the upper air valve mechanism outside to hold it open so whenever throttle is squeezed fuel will flow through secondary
